Mk2 Polo Saloon Repair Panels. Rear Arches?
hi guys my arches are quite rusted so just wondering if people know wherr to get repair panels as i can only find breadvan arches..
thanks a lot
  • Views 3.5k
thanks a lot
I'm in the same boat, and I think the answer is that they're not made any more, and nobody makes pattern parts (I think there were only around 1000 mk2 saloons sold in the UK - if that).
I've been trying to find out if the coupe rear arches fit, because I'm pretty sure you can get pattern coupe rear arches (although a quick Google shows they're not that easily found). You might even be lucky and find some NOS ones if you're persistent and know the right people (I don't).
My plan is to use bits of coupe arch to repair the rusted sections of mine, rather than replacing the whole arch - that way even if the coupe arch isn't quite right, it should do the job of supplying some pre-bent metal for whoever I find to do the welding.
Also - depends where it's rusted, but a pattern sill has a good 4-6 inches of metal at the bottom of the rear arch - and that's the bit that tends to rust first - so you might find you just need a sill.
http://www.carbodypanels4u.co.uk/volkswage...mk2/sill-full-1
Good luck!
thanks a lot
Good luck!
Cheers dude I think the coupe ones fit as my bro has a coupe and at a look the arches look identical. The lower bits the worst on mine but it's still rotted above but I only need it doing for mot then there being cut out in favor of fibreglass arches.
I'll let you know if come across anything mate
Coupe arches on their own are no longer available, you can get breadvan arches but that not going to be of much use except for the front part maybe?!?
You can get Saloon rear quater panels but they do not contain the full rear arch so it depends on where the rust is. You also might be able to still get coupe rear quarters from VW but they are expensive but they have the full arch in them.
Depending how bad it is you might just want to make up a plate/strips to replace the rusty bit
its really quite bad. inner and outer arch have gone really may see if my mates can make up some panels until i get the fibreglass ones on.
