20vt K03s Turbo And Parts
Got a K03S up for grabs along with the exhaust manifold, inlet hose and boot pipe
There is play in the shaft but it is ideal for a rebuild or even for the casing and the rest of the parts
Looking for £50 Posted
  • Views 283
how much play is there in the shaft and are the turbines of the compressor side damaged at all if they are fine i will take it all for the £50 posted mate pm me with your payment details.
there is about 1mm of play in and out then about 2-3mm of play side to side, as I said its good for spares or a rebuild. I haven't striped down the turbo to check inside but from what I can see it looks okay
yeah i will rebuild anyway i just mean looking in the inlet at the compressor do the ends of the blades next to the housing look bent at all, if you wiggle the shaft side to side do the blades touch the sidewalls
if not il deffo take it, if they touch but the blades arent bent or damaged il have it only reason i ask is if they are damaged a new compressor wheel is £200 plus unless you buy another second hand turbo thats all
Just took another look, and they are a bit bent, but they arent exactly touching the sides? can get another picture up now..
another close up pic would be great mate
Sorry for the poor quality.. as its my phone..
Edited by vee-dub90
SOLD!!!
