What Did You Do To Your Polo Today?
Where to start...
New front wheel bearings
New strut top mounts
New Koni adjustable front inserts
New CV boots
New rear brake shoes
New clutch cable
And a new MOT at the end of it...fngers crossed
  • Replies 1.7k
  • Views 82k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
Fixed the heating :)
drained cooling system and flushed,replaced antifreeze/coolant, new triple silicon ht leads ,
Fitted gt clocks for the rev counter then rolled and sprayed the rear arches now i have not tyre chunking :)
Damn you matt! :lol:
I've been playing with the 6n again. Got some black tail lights from GTI Fest sunday, so fitted them. Also got some 16v side repeaters fitted. Flatted back and cut/ polished up the rear quarter and sill where i'd sprayed it (with rattle cans, outside). Cant hardly tell where the blend is, and i've had much worse from 'professional' body shops. Well pleased :-D
Did a bit more work sorting out the bottom of the door, got it sanded down ready for primer. Put my centre caps on to see what they looked like.
Gave mine a service (1500 miles overdue!) and then washed and polished it, ready to get it filthy again as soon as I go out tomorrow. (I liove half a mile up a forest track). Am I in love with my car or just a masochist?
Looked at it.
May clean it later. Does look sorry for itself. But that's what it gets for always breaking!!
Bought another set of bucket seats to go in.
KNOB.... Coupe S interia looks the dogs bollocks ..
want to sell ? lol
Already had max asking haha! No way!
Buckets are because polo racecar
Let me guess eric, the buckets seats arent classed as a mod? :lol:
hahahahahah :lol:
mint, a class yo!
This thread makes me laugh,
Mainly Eric stating things breaking or people looking at their polo, thinking of doing something, then not.
Bump!
drove it to work and ting.
put the new gear knob on, then drove it to work .... exciting i know :lol:
Dryed the footwell out for third time in 3 days. Refitted the sound deaedening which had been drying on the radiator for days, after wrapping it in a bin liner to stop it getting wet. Put the front carpet back down, and refitted the seats, all in the rain. Interior has been drying out for a few days, but need the car later, so had to put back together. The reason for all this? Shitty door seal. Again. Second one now. First was perished, and leaked between the seal and the door itself. This one isnt perished, but leaks where the seal fits round the door shut. Nothing i can do at the moment either as have only another leaky one as a spare :x
i missed it :(
Tips - Bond the seal onto the door-frame weld flange with silicone, and ensure the window frame is true to the door frame (if not, adjust it using organic manipulation), to ensure a good seal between said frame seal and door.
Also, popping a small drill bit (like 4mm) through the lowest part of each floorpan will prevent puddles being able to form. No the carpets don't get wet in the rain. You can plug them back up with a rivet if you're not happy.
Been using mine daily because my golf is boring as fuck.
Done some megajolt related bits...
Machined a "hubcentric" spacer, and mounted it up.
Changed from ribbed pulley to V for chassis leg clearance.
V one sits closer in..
With this pulley I only have 4mm if that between it and the chassis leg, the OEM 60-2 won't work with my ECU so 36-1 and ford EDIS required...
Made this to space my trigger wheel clear of the dish, been a while since I used a lathe.
Bolted up..
Painted pulley too..
How the spacer sits
Clear of the pulley..
Checked it with a DTI, runout etc is fine.
Mocked a bracket up too, need to weld it and finish it.
Nice to have some enthusiasm.
Edited by harris.racing
oil and filter change
Why you no listen!
Nice work with the pulley 8-) It will clear the chassis leg though, won't it..?
Had a play with mine, didn't really get anywhere as I chopped some things up (exhaust, engine mount) then the welder packed up whilst fabricating a chassis brace..
Used mine to go and feed my horses this morning as the Landrover is 'hors de combat' at the moment after shedding a front wheel just before Christmas. Poor old Polo looks like a swamp monster at the moment after nearly a fortnight of bumping up and down farmtracks (Yes I have washed in between times, but the following day it always looks as if I hadn't bothered). When |I got back, the postman had brought me the wheel nuts and studs for the Landy, so I shall amuse myself by fitting those and then I shall give the Polo a damned good bath and hoover out. I shall also have a good look over it as it is due for a (one hundred and ) sixty thousand mile service and cambelt change plus anything else that looks as if t is going to drop off or fail in the next 5K miles. I attach a photo of its current (shameful) state. (Compare with my avatar!)
Why you no listen!
Oh I love the golf for what it is, just found some love for the polo too, plus that has fuel in :p
I should hope so, even with the wheel it sits closer to the block than the ribbed pulley, just the extra diameter and the crank sensor bracket maybe tight, going to measure up today to be sure though.
Could have done it many ways, but this way I don't need to respace the alternator pulley, it's adjustable for TDC reference, you can access the crank pulley bolt too. Need some smaller headed bolts, they're just for mocking up.
Nice to know you're doing something too Mikey, makes a change haha
Been to the breakers to find replacement front grill for the Kamei one i have on at the mo and a few more other goodies i found to bring my car back to original condition apart from the alloys i have on it at the mo .Did spot a complete Golf GTI interior but unfortunately both driver windows were smashed allowing rain and all sorts to ruin the front seats :sad:
Got pulled, got told to change the German font plates, or I could face a £60 fine.
Went to motosave, got standard plates, £20, better than £60!
