What Did You Do To Your Polo Today?
Completed my first DIY oil and filter change :-D Was pretty surprised with how easy it was! Also ordered an air filter online that should arrive soon.
  • Replies 1.7k
  • Views 82k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
Fixed my welder (soldered up the circuit board for wire feed control). Then welded up new exhaust section, omitting the catalyst.
Not in time for RR day though.
Fitted new clutch cable , now the gear change is as smooth as Ghandis balls aha
Took my Bready for an MOT - Passed with no advisories, woop!
if i was testing it i would have advised you fit some awesome wheels to those mega wide arches of yours :lol:
Well lucky for you I've got a set of these babies on their way ;)
YEAH BABYYYYY thats what i like to see!!
back on topic, I'm moving house to luton today so will be with my polo again! so the turbo will finally get to see its new home.
Just picked up a G40 interior then I'm changing the brakes and exhaust back to standard if I get time
looked out the window and considered cleaning it.
Realized this was the stupidest idea i'd had all day and got back into bed.
BACK into bed at this time? Lazy coont.
Just gave mine a quick clean !
Yeah, its how i roll... still in PJ's atm
You have PJs hahaha omg you never fail to surprise me yo'
finding out why the immo is not letting my 16v run. :disgust:
Yet again, what i wanna do goes out the window for fixing the family household cars instead - this time, the Golf gets a smashed oil sump, obviously just when i wanted to go to a clubpolo event, so i had to source and fit a new one instead. Wanted to use steel or maybe glass/fine china instead of fit another ally one, but the bolt pattern is way different.
Alloy sumps have bad aids, are more brittle than sugar cubes - and are like 1-2mm's thick! They're shyte, i need to replace the one on my Polo with a steel pan if i can find one with a suitable bolt pattern because i'm not chucking a ton away every time i run a cat over.
After hitting a lump of wood on some singletrack..
And new one fitted..
Replaced the oil pressure switch as it created an oil based spunk fest all down the back of the block.
topped its oil,thats about it
I BOUGHT it!
bought it a stage 3 subframe 8-) :cool:
Mikey why not make a sump guard instead be alot easier, better and cheaper in the long run
It's not even lowered, if it had a steel sump it wouldn't have happened. The oil level sensor in the bottom doesn't override the pressure sensor, so I lost the turbo too.
VW are retards for using ally sumps, plastic would actually be better if cost is the issue.
new flaps mud that is!! and a quick spray on my rear vw badge and handles inside in matt black
Changed 2 more coilpacks! And cleaned my spark plugs :-)
Gave her a really good clean, polish, interior. Scrubbed my old fabric mats (got rubbers now) and got them drying by the fire for storage later :)
Stripped it down to take 16v out.
Made a new exhaust for it, omitting the catalyst i previously ran (keeping AVY 4-1 mani, single 48mm downpipe & flexi from a Lupo into a 50mm main pipe and then into a single rear box).
Converted the worn ARB and rear gearbox mount threads in the body from M8 to M10 and fitted the suspension back up, sorted the engine mounts out and bolted engine in position, fitted the driveshafts, fitted a 1.4 crank aux sprocket to replace the weighted 1.6 balancer one, and fitted the alternator (90A as that's all i have here).
Fitted late starter motor back on with 6n2 cables, fitted 9n Sport cylinder head and cams onto AVY block with AVY gasket and bolts to complete the 1.6 Sport engine, set up bike carbs to how they should be theoretically..
