What Did You Do To Your Polo Today?
Didnt drive it too ultimate dubs :lol:
  • Replies 1.7k
  • Views 82k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
Made noise
Drove it. And went to UD :D
Messing about with a timelapse.
Stripped the turbo of the 100 PD lump. Despite 2.48mm of play in the inlet vane, the inlet funnel in the ally snailshell has only the slightest surface damage. So i'll gently polish it up a fraction on the lathe (exhaust vane damaged too, but less so, and no notable marking to the iron exhaust funnel). Cleaned up the wastegate mechanism, all ready to fit a new turbo cartridge/innards to.
Did wanna fit a bigger turbo, though.. :badgrin:
Mine's going in for paint tomorrow, yay!
Then that's is pretty much done. I think drive it for the summer then break it/sell it.
Buuuttt, I've discovered a thing called FreeEMS. It's an opensource ECU. Everythings free, basically. Supports 60-2 crank wheels, and the 32-2, too.
Should be good, once it's released..
Well, she's away.
Get it back Friday, hopefully, or Monday. HOW DO YOU USE TRAINS?! :lol:
Nothin, been working on a mates T4 camper
Replaced a dead rocker tensioner.
Tried another distributor and played with ignition again, just not getting any real sparkle from this engine, its missing something (doesn't help I can't hear it for the horribly loud raspy exhaust, which can't be helping).
Fitted longer front springs of circa 30mm drop - had the front down about 60mm to emphasize the rake reflected by the stripe, but the ride was doing my tits in.
Better to drive now, actually pitches into turns properly.
Had to whip the battery off to put it on charge. Stupid Polo. Could do with a newer bigger battery to be fair.
I've given up with ignition. It pulls well, but it's not right, and I can't for the life of me get it right. I don't know why I'm trying tbf, the curve doesn't suit the engine at all.. Haha
I'll be getting rid of it soon, anyway. The ignition system, I mean.. :ninja:
Gave her a wash and min detail, also tackled engine bay. shes now sitting lower tooooo :-) :-)
Took my plates off and cleaned behind them. Cut some velcro squares out and stuck them too my dealer show plates, then lined them up and stuck on the car, then pulled them off to leave the loop side of the velcro on the car. Now prepared for easy show plate fitment for this weekend 8-) . Refitted front plate. Rear plate has been rattling for ages as the screws holding it were too small and only just stayed in. Found some bigger screws, but bigger screws mean bigger, wider heads, so wouldnt fit in the screw caps :x . So got the dremel out and ground the heads down, a bodge but it worked. No more rattling, loose rear plate :-)
Had some LEDs delivered so changed the interior lighting and the rear number plate. :)
oh and changed a blown fuse
Found a small pool of brake fluid under the back of my mk2. Easy, I thought - change the leaking wheel cylinder. Hard line siezed solid, two cylinder fixing bolts seized solid. Cut the hard line and removed stub axle and drum backplate together. I have a three wheel classic for a few days while I collect new parts...
Sorted the non working electric window problem and fitted wind deflectors :-)
Had to ask Jon how to change the time on my 6n2 :roll::lol:
Retest? tut tut.... :lol:
at least it gets to where its going unlike the peugeot van!
Funnily enough, it was a peugoet van that was tied to the back of it yesterday as well :badgrin:
eco friendly these peugeot vans. seem to run silently too :lol:
thought about fitting my arb blocks and fiddling with aquamist loom and then decided i was too tired so headed home to sleep instead! maybe tomorrow.....
well I've just spent the last 5 hours in the garage, the car failed its mot on a burst brake cylender, so had to replace it which shouldnt have took that long tbh but after i changed it i went to bleed the brakes and the pipe burst, so running about trying to find someone to make me up a bit of brake pipe at 9pm wasnt my idea of how it was gonna happen lol after i got the break pipe fitted and all the components were stipped out and cleaned and put back together i set upon giving her a much needed polish :p photos below
before
after
and after polishing
1AM and still polishing a car in the garage haha i must be mental
port and polished the inlet manifold :) hasn't made any difference what so ever :lol:
Changed springs
Drove it several miles across Milton Keynes in 2nd gear, after the gearbox shat itself in an industrial estate, as it was the only gear that sounded and felt like i'd give me any chance of getting home - and yes, it rattled it's way safely onto the drive..
got all excited till i realised it wasnt a video of your car lol
Refitted an alternator 3 times and refitted a starter motor 2 times..
I have fully lost count of the gearboxes i've broken! Can't even work it out by engines as i'd lost count before i was using valver heads..
Hoping to get a good 1.6 box tomorrow, dunno the code but he says it's a Dragon green 6n 1.6 AEE in GL spec, so i'm hoping for a 3.3 final drive. Bit of a trek but i've got the 206 to get it.
Had a search under the car to find out what ever it was that i rad knocking loose after something went under it last night while worked :lol: .
turned out the part of my arch at the back that protects the auxiliary belt had come loose, no clips to get it secure again though :(, that's if anyone that part i am on about haha :p .
