What Did You Do To Your Polo Today?
Thought about finishing the wiring. looked out the window at the rain/sleet and thought fuck that.... went back to monging on the sofa!
  • Replies 1.7k
  • Views 82k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
as of yesterday i bought it
got all excited till i realised it wasnt a video of your car lol
I have fully lost count of the gearboxes i've broken! Can't even work it out by engines as i'd lost count before i was using valver heads..
Hoping to get a good 1.6 box tomorrow, dunno the code but he says it's a Dragon green 6n 1.6 AEE in GL spec, so i'm hoping for a 3.3 final drive. Bit of a trek but i've got the 206 to get it.
I dunno if it would be any good to you but I have a 1.6 AEE box of my Vento still kicking about. Only has 50k on it. £50 would seal a deal.
^^ PM'd.
Replaced a split pipe and cleaned (Another!) TB on my mate's 6n2.
sprayed my wheels purple :D
Removed the gearbox.
coolant change then rocker off cleaned it all up and a new gasket for good measure
It seems silly but the plastic cover was missing from the rear wiper so £3 and 2 seconds later job done and it was ridiculously satisfying
Fitted a gearbox into it.
Cleaned it and gave it a quick polish. Its amazing how much dirt snow leaves on when it melts.
Finished the TDi and ran it to Cambridge and back, runs faultlessly, now gonna have another look at my ignition and that's both cars sorted.
Was tempted for a while to put stock suspension and long mudflaps on it :lol:
You should have. Youve got the spots so would look pretty good i reckon.
Probably nothing
Discovered the universal coil i bought off ebay is too weak, sparks so weak i'm surprised the engine ran at all, let alone fierce enough to break a gearbox.. It says on the tatty cardboard box to only use it with electronic ignition. Clearly the wrong coil was in the box! It's dropping voltage too low once ballast has kicked in, so it's a non-ballast coil.
Dug out an old VW one and got a far brighter spark, but for some reason i couldn't get the engine to run with it before running the battery down. WTF.
Got two other cars to sort tomorrow, including a lift pump in a petrol Lupo which is always a bit scary, but i don't need the Polo until next week so i'll do it whenever.
Serviced the car on my day off
6E05D69B-20E5-4624-8A1A-D865246814B6-795
Fitted remote locking and reversing sensors and cleaned out rear arches and fitted the liners properly..
Put some petrol in it :lol:
Debadged it, prodded at the rusty door, and made it significantly worse.
:lol:
Treat rust with care, a soft touch is needed!
bought some 4 steel wheels, everyone seems to call them baby g60 but they are not just mk 2 winter steels
oh and broke down the other night forgot to add fuel
Changed my exhaust, changed the headlight to one that doesn't have a bullet like hole in
Also a throttle return spring
Elsecar Prep.
Proper clean inside and out.
Tightened driveshafts.
New pinstripe.
Washed it. Lowered the rear to compensate the raise for being stripped out. Swapped some jets.
65F6B526-9DEA-442E-AF12-265CDDD8527D-378
Fitted 15" alloys and new tyres.
