What Did You Do To Your Polo Today?
Me and Pete took my engine out yo!
  • Replies 1.7k
  • Views 82k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
1.8t. Couldn't afford the R, and the burds TDi makes me hate life.
Seems nice, really clean, gunmetal grey, solid, needs handbrake sorted, but other than that, brilliant. Wanted 1850, but the spazz that put the advert on the internet put it at 1500, so I got it down to 1400 because of the handbrake.
BREAKING MINE, FOR PEOPLE THAT WANT SHIT..
Sounds alright; AGU 150hp? Big port head y0
No work on a polo as I'm without one :-( but spent the afternoon and early evening pulling last Sundays "Pod" burnt skin from the top of my head :lol:
Went for drive in my friends GT and it threw a rod.
Fun times :(
yesterday i asked the bodyshop if i could have my windows back.... They said no :(
Tested the ohm resistance of all the spark plugs is I own, record held by a Bosch item at over 170,000 ohms.
It should be under 6,000.
Sounds an effective way to see if anything's more boring than formula 1 Mikey!
Hoovered and brushed inside of car, cleaned abit of the outside and gave the exhaust one last check to make sure its not leaking
Fitted new rear brakes and adjusted handbrake, bearings and sorted the number plate lamps.
Went to fit my alloys and found one was flat, cock.
Washed it and finally got the splitter fitting properly.
Yesterday bought my polo breadvan for £200.
Spent yesterday and today on rust removal duty, and a good old t cut. quite pleased how clean it is even after a single t cut - no polish yet :)
Any one know what colour this is?
Blue
Blue
idiot. I showed you what your wheels are :lol:
Blue
Round metal ones? ;)
You'd think so wouldn't you, but to my surprise it was actually less boring. F1 still holds the title.
Still, it was close, and would qualify as the sort of anal practice I like to avoid, but with continued ignition problems it was necessary.
Actually Steve, if you find yourself interested in having a go at it yourself, I'd be interested in knowing the typical ohm resistance of a late MK2 spark plug and HT lead.. :-D
417817_10200941139719982_1620071486_n.jp
Fitted this roof basket I bought for £10, apparently it's over 30 years old. Next up is fix everything it failed its mot on, mainly brakes as the garage managed to snap the handbrake cable during the test.
My Dad had one of those in the early 70's :lol:
Fired it up to realise the exhaust clamp i rotated 90° to clear the road is now vibrating on the transmission tunnel :(
SO Glad its not just me thats done this!
yeah turn the clamp round for an extra few cm clearance (y)
dropped the beam and tank. Painted tank and filled the pin hole in what i found on the filler neck with chmical metal ..
Bcus i want to be like ericcc <3..
Looked at it .
Looked at my scored engine .
Got dipressed so made a sunday roast .. lol
Depressed.
Erm I drive mine usually, too much fixing not enough enjoying in this thread !
Had a look at the AFH head, comparing it to the 9n head. Set the cams to their marking for TDC and rolled the cams to compare lobe timing difference. My latest suspicions were founded alarmingly - the 9n head is backwards! Cylinder one is at the cambelt end with the AFH and all pre-'99 Polo engines i've worked with, but the cams in the roller heads i've got are back to front.. So instead of cylinder three's inlet closing and cylinder four's inlet opening when it's just gone past the timing marks, cylinder two's is closing followed by one's opening. What's that all about VW?! Why just decide to turn the cams around..? I've been running the HT leads backwards all along.. :smoke:
Next i wasn't happy with the cracking all the way around my thick rubber inlet manifold gasket, so i took the manifold off - only to find most of the gasket missing, all been eaten by the engine. It's not a case of whether it was leaking or not, more which cylinder was leaking the worst. :retard:
Obviously rubber is no good then, so i made a new one from a sheet of very tough polyurethane, which took ages because not even a fresh Stanley blade would cut through it without a fight. That should last a bit longer.
So my attention was then drawn to the rubbers that hold the carbs to the manifold. Original KeiHin ones. The ID of the tapered middle section had shrunk to about 25mm! What happened there? So in the bin they went, because i hadn't sliced my hand open yet, and i figured after an hour wrestling with the gasket i was pushing my luck. I still have some industrial tubing i'll use with the carbs butt-up to the manifold, i've worked the ends of the runners so they match the carbs perfectly.
The 900's that is, as i found them in the shed and decided to try and save them once again, after welding the pilot screws up with cheap petrol. Thanks ASDA! So i cut a deep groove in them with a Dremmel, used a defined-flame blowtorch to heat up the casting, dropped some oil on there to cool the screw and immediately went at it carefully with a flathead - and it worked, all four CBR900RR carbs now built up and ready to go on.
Next spare day off
I didn't get chance to do anything on my polo because my day was taken up by reading what Mikey did
