What Did You Do To Your Polo Today?
changed the oil filter after much swearing and stabbing. Someone (not me!) didn't realise they're only supposed to be just tight and not stupid tight! Hopefully the oil leak from behind the sandwich plate is fixed now.
  • Replies 1.7k
  • Views 82k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
Nothing, but I have just been trying to work out this backwards head.
So going by the cam lobe orders from TDC, the pre-'99 engines fire in sequence 1342, but post-'99 and its 4213.
Rotor arm then visits..
In the first case - 13421342134213..
And in the second - 421342134213..
Which, once running, is exactly the same. I can't deal with this right now..
fresh gear box oil change put in some 75/90 gl5 seems a bit sweeter now
Changed oil, sparks and all filters, thermostat and housing, washed, polished, waxed and hoovered!!! Now running and looking as it should!!!
Tested Fitment. :-o
Went to put on some BBS RAs iv refurbed to find my wheel bolts are too short, then swore lots
Fitted everything back up, sleeved all the cables, put the dizzy cap on, put the leads correct on the dizzy cap but plugged them into the cylinder head in reverse order, connected the battery, pumped some fuel through, pulled the choke, turned the key, and it fired into life.
One engine running sweet with the leads on in their new reverse order, now just to get the CBR900RR carbs set up properly and hopefully it'll be back to running tip top.
Drove it to the petrol station on the way to pick the toddler up from nursery, when i got out i was shaking so much i nearly dropped the fuel cap. The toddler doesn't share my newly restored enthusiasm.
Anyway, nice to have it back running as it should, even if my now-connected temperature guage is worryingly off target (sits around the absolute maximum mark), and my first attempt at balancing the carbs has left it without the stealthy smooth idle i was aiming for.
I was gonna wire the stereo in, but i don't really see the point. Need to look at an ABS sensor on the Golf instead, after a stroll to the lake to calm down said toddler.
^^Lies
There's no lakes in MK :lol: Reservoir maybe
Edited by prankstar2003
Apart from Willen lake, Caldecotte lake, Tongwell lake, Loughton lake, Willen lake, Knowlhill teardrop lakes, Furzton lake, Linford lakes, and various other smaller lakes thanks to the Ouze running through.. :roll:
Sure some are man made and reservoirs, but i haven't included the balancing lakes - as they're usually houses :lol:
Having been at work, then having to go to the monster-in-laws right after work, I only managed to changed the heater panel light. Now I've got to work out why it's only ticking over at about 750rpm rather than 825 - 850 as it should......
Got some 15s for the coupe
bought piston rings yay
When you hoping to get the 1.6 in Eric?
no idea mate.
need to buy a 4 branch, make a new inlet, then the rest of the little bits n bobs.
I see I see before or after polos show that's the question??
probably after tbh mate
Had a bit of a nail-biter.
Out in the pissing rain today (bit frustrating given i've become used to having some traction with the Golf - strange how i can brake hard without locking up, but can't even accelerate in third gear without the front end and rev counter being all over the place), and it was smelling strongly of fuel. So i pulled over and checked it out with the engine still running - to find one of the carb vents pissing fuel out all down the back of the engine and on to the exhaust..
Sat there with a fire extinguisher in my hand for what felt like eternity, until i was half soaked, happy i wasn't gonna need it. Removed the baths of the two carbs in question, and inspected the valve rubbers and springs. Fine, so i looked at the floats - one had some weight to it, the bigger side was full of fuel.. Had a crack in it, so i broke a chunk off and made a bubble with a bit of carrier bag, sealed with a strand of speaker cable. Put it all back together and my makeshift float did the job to get me home.
New float fitted when i got home, now all good. Can't believe i didn't spot it when putting the carbs together, just shows what can happen when you rush the job when working.
Collected my recon gearbox for the GTI today..
I havn't officialy done anything to the polo except spending cash on it..now theres a surprise. :D
fking everything. to pass the MOT
did a burnout like a yob
Mikey what's going to break just before the next show then?
His laughing bone ..
Gave the interior a good seeing too!
Vinyl and rubber care, glass polish and vacuum! :-D :-D
Too rainy to clean and polish the outside boo :x
A trend, hopefully..
