What Did You Do To Your Polo Today?
Mikey what's going to break just before the next show then?
A trend, hopefully..
Haha like it
  • Replies 1.7k
  • Views 82k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
Nearly got run off the road by a complete c**t on the M4!!!!!!!!!!
Fitted a new clutch, new disks and pads, Poly ARB bushes, new top mounts and New PhilJ front shocks.
Its go a bit of reverse rake now :( I think it must be the new top mounts. And it knocking on the OSF so got to have a look at it.
Did a bit more work on my adapters...
263122_10151446922585662_2047703819_n.jp
sobbed when i saw the state of my paintwork...
fitted my nice backbox and un-tinted my lights
Painting wheels indoors.
Will - i probably made that squirty bottle! The orange conical thing. Several years ago at a minimum, proper blast from the past (i didn't make the trigger though, they were made at another factory).
If you look on the bottom of it you'll find a squared version of the letter 'a' and a number between 1-9. And the material, which would've been HDPE which it will also say. Most of those are long gone, so if it still doesn't leak it must be one of mine
And i like the makeshift oven.. I spent hours heating my entire shed up to get a good crinkle finish on a cam cover, didn't think to just use a well insulated box like you have there.
Eric - i like those lights (recon i'd have the indicators orange though), makes me wonder - is one reverse and one fog? If the fog is capped with a chrome lens then what, is the bulb red?
Just thinking about getting a LHD reverse and converting it to a clear fog the same way. Went for twin fogs to give it a legal symmetry, but i think twin reverse would look better and would give me both lights!
yeah reverse and a fog. the backing plates are standard. just clear lenses. you can either get a red bulb or a chromed red one similar to my indicator bubs to stop them looking like fried eggs :)
I forgot to put what i was in here for.. :retard:
Well i tried to get the other two channels of my retrotastic (shit) Pioneer KEH-4000R head unit working, but one rear channel isn't working. Three channels would be good (two for the front doors and one for the centre dash grille), but two = 2x25w and four = 4x15w so i don't know quite how three would work.
So i looked at putting my Nikkei (shit) 2-channel amp behind the glovebox to drive two of the channels, then have the third channel for the middle speaker.
Or i might just stop being a pikey and buy a head unit i can plug a stick into, with four strong channels. Which will probably look like a pair of Nike Air Max 2013's on a victorian coal miner.
attempted to fit my PPP subframe.......
got one lower arm bolted in and one arb mount.............. and then gave up for today :lol:
Fitted a speaker pod
just one?
Fitted new rear pads and disk and lowered the back more and done a gearbox oil change
just one?
Yeap lol. Seeing how it fits & need an amp first
I broke mine today. Cleaned the throttle body then the bloody thing was over-revving. Got to get a TBA at some point this week.
Update: stripped 16v engine
Left the side lights on for a few hours, which will almost certainly mean a flat battery because i have twins front and back. I'm gonna need to wire-in a 'lights on' buzzer, as i always have my side lights on regardless of the time or conditions "like sweedish cars"..
windows in exterior parts on and started wet sanding today nearly done
took out the 6x9sin that parcel shelf now need a new parcel shelf as this one has some perfect ovals cut into it
Turned the steering wheel left and right a bit to work out whether brake judder is steering linkage or caliper slide bolts
Then it started raining, again.
Ran all my fuel lines in kunifer, built new exhaust hanger brackets and welded them on
Finished filling stone chips on the bonnet still not perfect thanks to 2 parts where i wet sanded through the clear coat gave the bonnet a machine polish to remove the sanding marks and it looks amazing sadly its raining now but still put a few coats of wax on it. also passed my mot on Friday no problems :D
Waved goodbye to the car as it was loaded onto a recovery truck :(
Swore a bit more as I saw the auxiliary belt tensioner shit itself in my rear view on the motorway this morning!!!! Fun doing 40 odd miles on just the battery!
