What Did You Do To Your Polo Today?
Smashed front bumper, bent wing, bent grill surround, crushed bumper iron. Luckily nothing, suspension/steering wise.
Could've been worse, these things happen.
  • Replies 1.7k
  • Views 82k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
dam.. :( .. yeah could have been but still..
Spent the last hour of sun light cleaning my boot well and re sealing anywhere i think water might have been coming from, chucked a load of silicone round my light clusters too, anyone know what else I can do other than this temp fix? It's always the left hand side of the car that leaks too :(
Got it stuck on driveway
Fitted some yummy wind deflectors in my lunch break :)
Today I found one of the "cold start" problem (hope the only problem). I have now to "create" some ring to put on the distributor, to get no vibrations on it.
Boot still leaking, removed even more trim. Turns out at some point the back left side had been shunted so the lights don't sit flush... Found a dribble of a leak by pouring a bottle of water over the cluster. (No where near the cluster by the way) then ran a hose over it for 10 minutes but no more came out, typical.
Run it out of fuel as the gauge is as accurate as the weather on tv :-/
Fitted a voltage regulator on my 1991 coupe gt. Made a big difference.
Went to collect some interior for it in a pickup with parkinsons :lol:
got it out yesterday and gave it a wash, parked it down the road whilst i worked on the vans exhaust. surprised how many people stop and look when the owner is not about
Fitted my modified front top mounts. Tried some different front springs to help handling, pitch balance and ride, set ride heights etc, needs a geometry as wheels well off. Feeling better though.
Will corner weight and setup properly at a later date
prob burnt a years worth of rubber! testing my new bike carb install that id spent the weekend fitting ;) happy days! :D
I tinted my breadvan lights
Tell me more ?
I got my hands hard working and smoothed my front rub strip :ninja: would post pics but I am unable to do so :sorry:
Bought a new fuel tank as the cursed filler neck has sprung a leak and found a steal on a an original Genesis interior, jumped on it like a tramp on chips! Onwards and upwards.
Roof wrap!
Drove it to work to work and back and made some whooshy noises with the dumpvalve :)
ECP finally sent me the right water pump. It can all go back together now :smile:
Replaced the screen washer pump on my mk2f gt. Cleaned out the tank which took for ever. Reconnected everything and topped up the fluid. Keys in the ignition and tried the new pump to see if it worked. Tried the front first, pulled the arm towards me and the wipers worked but no fluid yet it was making a noise. Looked in the rear view mirror and discovered the rear screen wash was working. Pushed the arm away to run the rear washer, the arm moved and the screen wash at the front worked. Totally reverse of what it should be. Solution. Reverse the cables in the multi plug on the top of the pump. Works fine now. Pump came from V W heritage.
Lowered it a little more, need new wheels to go lower :(
Took it for a spin in the dark before i remembered what crap headlights it has and a windscreen that seems to have a lot of marks on it.
It wasn't today, but yeah, you get the idea..
Taking a roundabout, and the woman in front of me decides to change lanes.
I've had enough. I've had it over seven years now, it's the car i always wanted it to be but i'm at a turning point. I wanna keep the engine (2005 Seat Leon BCB 1.6 16v with GTi block and late 6n 1.6 gearbox) but i have other plans. It has 7 months MoT and 6 weeks tax.
So today, i have partially decided to let it go.
Edited by MikeyMK
Bought a new one
had a 6n for years but after some critical problems I parked it up and bought a clio as a run around.
with the clio out of mot I bought a 6n for cheap money.1.6aee per my previous.
its not quick but I'm old enough not to be bothered,has air con ect and just a few minor issues to sort,bodywork is pretty good for its age.
will use my old 6n as a parts whore and lows and smiles will be the new,again
