What Did You Do To Your Polo Today?
Excuse the awful photos. I used one of those awful apps for Instagram to get a before and after shot in the same post!
(Also, that sunstrip :lol: )
  • Replies 1.7k
  • Views 82k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
I ordered a rear wiper arm for "Heidi" my blue 1998 1.4 cl Polo
Yep! that, "fits polo mk 4 onwards,golfs mk 4 onwards" line and I fell for it ...too long being returned ...
Edited by thojj
this arrived today :) CTVW028
fixed my 6n2's head indicator, happy because 2 of the clips are broken and also the metal clip isnt placed well in its place, but still mangaed to get it solid placed without moving, proud of myself :)
Realigned/adjusted all the gearbox stuff so I can get into first! Yay!!!
Started puttings parts back on, still pretty much a bare shell though. It needs to be on the road in 26 days.....
Started tackling the dent in the passenger side today. Bought a heat gun, didn't use it. Money would have been better put to some trim removal tools, but thankfully the rear card was not entirely destroyed.
It ain't perfect as yet, but it's better than it was. Before/after:
The drivers side card was already broken when I got the car, with the metal rail at the top almost completely broken off. Decided to take it off and see if anything could be done. Had a look inside, found lots of rust.
Also I feel like you're not supposed to be able to see your tyres from inside the car.
Note to self: avoid deep puddles.
So there's that to sort out which adds to the long list of problems... however I did managed to get that metal bit back on to the card and the whole thing fits back on perfectly now... so I got that going for me, which is nice.
To be fair that looks much better. What did you use?
Just gave it a few light taps with a rubber mallet from the inside and it popped back almost into shape, no paint damage :D
Ordered rear wheel bearings - for the weekend
Replaced pancake filter with golf elbow + pod
Painted cam cover, heat shield & scuttle tray
Engine dressing kit
Before:
11150665_10206918005973726_7964158280065
After:
11257071_10206918006373736_7839542265138
Engine bay transformation for under £50 :D just need to connect the oil breather hose and it's done
Today i clean primed and painted my bumpers - to be fair not a brilliant job but has really cleaned up the look of the car.
Need to paint the rear arches and the sill covers as well.
Today i took the loon out for a bit of a post MOT shakedown.
Its literally only covered about 600 miles in the past 4 years and only to the MOT centre and back a couple of times since the engine swap.
A few items came up that needed some adjustment and it seems to have a strange noise to investigate (hoping its the DIY air filter box whistling) but other than that was really getting into it and giving it a few beans down the bypass.
First of all I was disappointed as it felt quite slow, but all my normal cars are actually quite quick and it actually isnt bad at all for a 1.3.
I fitted some RA's.
Black sunvisors ready for my tartan roof lining :D
Also meet Frank my new travel buddy!
He will be attending shows with me as the missus is not liking the vw scene, so will be at work instead but hey ho
Edited by xumado
ordered a 270 cam and followers and got some bits powder coated the other day
be dropping it off at a friends garage in a week or two to have:
• strut brace & subframe fitted
• gt rear beam & polly bushes fitted
• rear brake hoses replaced
• 270 cam, vernier pulley and followers fitted
• g40 injectors fitted
Replaced the oil breather hose. Old one (or what's left of it) on the left, new one on the right:
This answers quite a few of the questions I had regarding the state of my engine bay.
:lol: bit short. Deteriorated over time I guess?
I gave mine a sound thrashing in the sunshine. Really enjoyed it!
Yeah, it was originally the same length but the thinner tube just disintegrated when I first tried taking it out :?
Ah well, tis sorted and she does seem a lot faster now :D
Edited by Vio
Not on a Polo as I have an Ibiza, but it's also possible on the Polo's.
This morning driving back from my Tesco weekly shop, the speedo suddenly stopped working, all other instruments working OK pulled the connector off the gearbox sensor and it was full of water and the socket & pin for the power (Black/Grey wire) was a lovely shade of green corrosion, cleaned it up and the speedo then worked :)
The reason the sensor & plug were full of water, two weeks ago for the third time in 18 months, the thermostat housing had cracked :( and sprayed the coolant out directly above the speedo sensor.
So if your speedo suddenly stops working, pull the connector off and check for corrosion, obviously this is only applicable to electronic speedo's
You're not having much luck with thermostat housings, are you Nige.
Fitted a genuine VAG one this time :) £80.60 + VAT !!! compared to £36 from ECP but you can see the difference in the quality of the moulding and why it failed in exactly the same point each time
fit this
to fix a small leak, and hopefully eliminate the burning oil smell haha
Fitted front suspension just waiting to do the rears after soaking the lower bolts in WD40
