What Did You Do To Your Polo Today?
got another set of valver bumpers for cheeps and they came with a certain grille I need :D
  • Replies 1.7k
  • Views 82k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
Found the oil leak and hopefully fixed it. Find out tomorrow morning.
Also booked its MOT so I can legally drive it out there. So tomorrow at 08:45 I will be a nervous wreck!
Changed the clutch cable and continued trying to clean months of gank out the engine bay!
Bad news :( the Ibiza passed it's MOT this afternoon, so I'll be keeping it for a while longer
Nige! I need your expertise in my thread <3 <3 <3
And my Polo passed its MOT with no advisories! Join the club. :smile:
I had one advisory, the same one for the last 4 tests, "Exhaust is close to the brake load limit valve" nothing you can do about it, just the way the pipe is routed.
Looking at the mileage from last years test I've only done 2675 miles, hardly enough to justify having a car !!!
At least an MOT seems to be consistent for once...
A lot!
Whole day and a half so far - unfortunately my curiosity on my exhaust rattle meant its now hanging off waiting for more attention tomorrow - but I&#39;m supposed to be driving to the social in the afternoon!
Spent a good 8 hours cleaning and polishing. The second leg of my journey to the social starts tomorrow :)
Relocated the alarm to behind the coolant tank, aka 5 inches away from its original position.
All I did to mine yesterday was replace the boot struts since they gave way and I had a spare 5 mins to my self and if I get any spare time today I might change the indercators to clear ones and might even fit a coilover kit :)
Today I put my rear coil overs on I had a spare 10 mins to my self and I changed my indercators I'll probs do my front coil overs tomorrow
Insured it and taxed it. Now it can live on the street instead of my drive way.
Fitted rieger splitter and wind deflectors
Drove it......very carefully
Yesterday I managed to sneak past the F1 security at Silverstone and drive through the paddock! After that I hit Lands End and Lizard Point.
post-2904-0-23634400-1435736020_thumb.jp
post-2904-0-29457500-1435736122_thumb.jp
Normally the Land's End tourist photos are pretty cringy. This is the best one I've seen. ;) I like the 'It made it' :lol:
Put more gearbox oil in it, ignored the gearbox whine, reset the engine management light when it came on because my emissions were excessive because of my bad catalyst, reset it again when my engine overheated on the way home, wondered if my radiator fan had broken again, parked it with the windows open in the hope that someone would nick it. :tongue:
Only a few more months and I can say goodbye to this infernal machine, which I love so dearly... :-(
Edited by acme15
And today this happened...
post-2904-0-26411400-1435791934_thumb.jp
post-2904-0-21455700-1435792133_thumb.jp
The car has been brilliant!
Just some electrical stuff...
post-918081-0-71501600-1435845225_thumb.
Edited by Vio
Or hardly enough to justify having an economical car ;)
If I did that sort of mileage, I'd be driving somthing a bit faster :)
If the insurance was reasonable, I'd have something with a V12 if I'm doing 2675 miles a year! :tongue:
Well it might come to that as it's been having cooling problems for a while:(
Today did a compression test 180psi +/- 10psi across all 4 pots, No normal signs of head gasket problems (oil in water, water in oil, mayo etc)but I did a "Sniff test" and this was the result
93A37696-4C15-4DB7-89E9-E1B431CFA791_zps
Indicating combustion gasses are getting into the cooling system :((
Next step is pressurise the cooling system and have a look in the plug holes with a boroscope to see if I can see if it's the gasket or a crack in the head !!
Put on a seatbelt cover and some suspension caps. Tried to fit an arch spat but realised my arches are more rust than metal. I really need to make a start with some bodywork.
Also gave a jump start to a Mercedes. Feeling weirdly proud.
Tried to find the source of my exhaust blow, found the nuts holding the turbo to the manifold had become loose somehow so tightened them up, also tried jiggling the system itself to make sure it is sealed. Still sounds like I've got a small blow but I'm at a loss as to where it is.
Also noticed one of my water pipes has started to melt as it was touching the turbo so re-routed that.
Finally ordered some bits to finish off my home brew oil catch can so I can stop covering my engine ebay in oil....
