What Did You Do To Your Polo Today?
engine coming out again! :D
  • Replies 1.7k
  • Views 82k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
When I drove my mk2 back from the bodywork place having had some rot sorted I noticed my throttle kept sticking open, so today I cleaned the area and applied a liberal amount of white spray grease. Hopefully that'll sort it for tomorrow's mot.
In other news I found out that the spare key I've had cut works but only just. It takes some wiggling. Might have to look into getting new barrels made up because I assume the lock and key have had 30 years of wear and have worn together, the new key doesn't have the same wear and hence doesn't quite position the pins perfectly.
get em to run the key through the machine again , they copy the worn out key so it ought to work if the original one does
I did think they just copied the old worn key. Do you think getting them to run it through the machine again would solve the problem? Is it just that they haven't copied it quite right?
EDIT: I've just compared the keys, the old one on the right in the first picture (key1) seems to have a slightly different shape near the base. I think this is most likely causing the problem.
It's hard to tell from pics 2 & 3 but I think parts of the key may be wider too. Do you think this could be contributing to the issue? I'll take it back for a recut ASAP.
https://www.mediafire.com/folder/npvhybfin6mkv/keys
Edited by Saint Jimi
It won't work properly if the key is over-cut either. I had this. It wasn't much but it caused it to stick. I took it back and got him to cut me another one (after a brief dispute about how different view were).
The reason over-cutting also kills them is because the locks in the barrel can protrude both ends - they have to be held dead centre, so either side of the key line will cause protrusion.
Was pleasantly surprised to learn the 6n has a boot light :smile: but the bulb in mine was blown, and the only bulbs I had on-hand were from my old Polo, and... well, you know :tongue:
looks like its xraying the bag
I managed to "fix" a coolant leak (by fix I mean bodge, radweld really had no place in the coolant system!). It does seem to have worked though, no hissing when engine switched off and coolant level not dropping... Just need to work out what's going on with the Speedo and rev counter now, only working intermittently...
Dug out all the cornflakes and Weetabix, sat and stared at the captive nuts for the rear axle, and in despair at how these things structurally rot from the inside-out, i decided to condone the car. Sorry guys, another Comet Blue Coupe S bites the dust.
So i had a word with the DVLA and it seems our horrible Tory government have actually done something useful - the laws on personalised registrations have been slackened, and they've now agreed to retain my plate! Yeah boy! So i've now retained it for another car.
Surprisingly, they still have it's original plate to hand and have allocated it with that. So within the next few days it will have it's original plate for scrappage/sale.
My other Polo is a tidy and original MK2F Genesis breadvan. 'B2UVA' would sit well on it, i think. As with the 1.6 16v, big brakes (and servo!), H&R kit..
Its all pondering and planning, today.
Fitted an engine... first time in 8 years this has been in the car
Turned the brake pad around on the bake of the 9n. Some idiot had put one in back to front :paranoid:
Look at that bad boy! Pure powah!
Could've at least given it the tartan treatment..
Your doing it all wrong. What you need to do to rectify terminal rust is fill the sills full of Krown T40 rust inhibitor.
The sills aren't the problem (apart from jacking damage over the years.
The chassis leg has disappeared. The captive nuts for the rear beam are on show.
There's are a lot of problems - the front jacking platforms are crushed right in so the floor pans aren't right. There's rot in the front valance. The rear valance has seen better days, too. Look at this picture and it nearly shows why i could probably tear out the rear towing hook with my bare hands - the chassis leg and entire corner section behind the bumper end have rotted..
But i could fix all that, it isn't structural really. I don't mind welding panelwork and i don't care about the chassis leg or towing eye there, it's not important. The front floor pans would be a pain to chop out but i have spare ones cut from another shell (although it'd mean cutting the front chassis legs where they meet the jacking platforms, and the whole area is a bit out of my comfort zone).
The rear axle mount, however, is the problem. Look at where the petrol pipe bends to go under and there's a fkn great big hole in the body right behind that bend. That is the chassis leg. Or rather, lack of it. The captive nuts for the axle mount are on full display.
Of all the work this shell needs, i could do most of it, but i really don't like that. I'm out of my league with that.
If someone else wants to have a go, they're welcome. I'm gonna pull some bits off this car, in fact i'm gonna pull a lot of bits off this car and it'll only roll well enough to get onto a trailer at best, but they're welcome. I'm not doing it, though.
Anyway then, this happened today..
Now then Guy, about that rust inhibitor..
That would be a walk in the park for some krown, the Canadians love it don't you know lol
I had to do a similar repair on a bready not long back but I only had access to it from the back, was a pain in the arse. All in it looks like a pretty big welding list for a mk2 polo . As with everything you need to know when to draw the line
I like it...is the stripe down the side red? I'm a little bit colour blind buy it looks cool mate, taking it your swapping everything over?
I'm colourblind too - i think it's just black, i dunno. It goes up the rear pillar so is probably the factory job, i thought they were red/black on these but i didn't notice any red.
I'm not going mad with it. In my 12yrs of modifying the Coupe-S, experimenting with it, i've learnt a lot. And i will be using that wisdom to make the new one just how i want it. My attitude is 'less is more' and although it won't be the nutter of previous times, it doesn't need to be.
It is also a 1985 model, a replacement car entirely but in spirit it just feels like it's just another evolution, so i shall keep my gallery thread going - without even changing the title.
I blanked the plates because the blue one has a new plate allocated to it and the white one is about to lose it's plate. In future photos, in the gallery, the white one will display it's new plate, which the blue one has carried since '07.
I was watching that white coupe S on Ebay cos it's exactly the same as mine and I wanted to get an idea of how much I could consider mine to be worth. It is the one with two passenger seats isn't it? I'm very glad to see an enthusiast got this car.
(And if you ever happen to want to swap out the interior I would love to have replacements for mine, just putting the thought out there) :D
Also out of curiosity, does your blue one have an S badge you'd be willing to sell if you plan to scrap the car?
I was close to losing it, as I was out of town with no battery left in my phone half hour before. I'd watched it all week, viewed it, the guy had emailed me underside photos (sound guy), and there was me nearly losing it - so I had to go for a one and only bid..
The white one is missing its badge, and i'm gonna use that. You might wanna give me a nudge in a few weeks time about the interior though - if my mouldy late interior cleans up i may use that instead (i prefer the pattern and the non-bolstered seats). And though it has a passenger backrest, the old driver's backrest is in the boot.
Paid a garage bill of £225 for recovery of the 6n, fitting of some parts I'd bought, fitting of some parts they bought cause half of mine were wrong, and fitting of some parts that I was unaware I needed.
Resolved never to go to a garage again. Even if the head gasket goes, I'll fix it myself.
Diagnosed a slow puncture in one tyre. About to go back to the garage to get a new one.
is that the new polo you got ? what happened now?
"Resolved never to go back to a garage again"
"About to go back to the garage"
[emoji38]
Yep, this was after I unententionally drove it through a puddle and destroyed most of the electrics. Have replaced the rotor arm, dizzy cap, spark plug leads & ignition coil and it's running fine again now. Also put on a new fuel filter, and the garage added some exhaust clamps as apparently I had none :?
Learned everything is not as bad as it seems :smile:
Symptoms: Unfamiliar rattle/vibration sound from rear of the car at high speeds.
Initial thoughts: Possibe wheel issue, or suspension-related fault (springs were in bad condition already), or loose exhaust, worst-case scenario rear axle is damaged.
Cause: Twig stuck in wheel arch.
