What Did You Do To Your Polo Today?
Replaced the rear bearings ..
Shall replace the shock on monday, then a good wash and retest for mot :)
  • Replies 1.7k
  • Views 81.9k
  • Took the 6n for a 60 mile drive today, got filmed driving it & I was interviewed for an upcoming TV series "World's Deadliest Drivers". They'll be using my dashcam footage from both of my accident
  • dougstar21
    dougstar21
    This is you Mark: Changed the oil filter today. Changed the spark plugs today. Topped up the screen wash today: Replaced the rear tyres today: That poor engine is never in the car! Ha ha.
  • Well my car has now gone on its own little travels Next time I'll see her she will be outside our house in the USA
sprayed like half a can of silocan spray onto my top mounts to stop them squeaking.... it FAILED
got some braided brake hoses and drove her to and from work. freshly taxed and insured, shes having alot of time on her tomorrow though
changed the black sensor to see if i could stop the light on the dash flashing - it failed!
tried to T-cut the car and failed......
so i washed it and buggered off inside! :lol:
Fitted an oil pressure gauge. Wired up the illumination & made a braided hose for it.
Wished I was working on it not the Audi.
harris - liking the modified centre console with the switches ;)
Drove into it. :retard:
Fortunately i was driving a 206 home from the night shift, it's bumper deforming obligingly, and the Polo's paint (and arch trim) seem to have survived - even if it reflects the light slightly differently now the front wing panel's warped.
It'll wear it with pride for years to come, it's only a car, they get battle scars. Still, sleepy time for me..
Cheers man! I'm pretty impressed that at the time of taking the picture the AFR was 14.7:1 haha!
And mikey you and your late night/early morning drives hey :( I'm gonna sign you up to some sort of energy drink subscription
Harris are you are vaccum take offs just held on with chemical metal?
The inlet tracts are drilled and taps 1/8 BSP I think but as there's only a 3mm wall thickness I used metal set too.
Usually when I fit instrumentation tapins to things like plastic inlet manifolds a bit of metal set usually goes in too, and they survive just fine :)
Was a bit of an afterthought and I don't like them tbh but oh well :)
ah right cool.
was just asking as i was thinking of putting some in mine with chem metal as welding is effort
I use it as a thread lock/sealant also haha, it's awesome stuff! Seems alright still now anyway, and my inlet manifold gets hot!
awesome duuuude. i need a aee manifold.. make me onneeee safee
I might get some base plates made up and knock a couple out. As long as the base plate also fits the 1.3/1.4 too
I tapped the EGR hole in the AFH iron manifold to take a bolt in order to block it off, but the hole was a little big for the tap (M12 i think). So i torqued it only gently and used chemical metal as a threadlock - i got that manifold almost glowing hot and it was fine for many thousands of miles!
Still is, though it's in the loft.
took my shock off ready for when the replacement comes tomorow . Did some magic thought and took shock off without removing the strut at all..
Mwaha
Cleaned it inside and out. Satin blacked my rear number plate plastic handle thing.
Most effective thing is cleaning the underside of bonnet, didnt take a before pic mind.
few bits after work here and there this week.
replaced complete passenger hub,and balljoint.
clean and greased the collie threads
greased the brake caliper slides
new rocker gasket and oil cap
oil flush,new oil + filter.slight polish of the rocker cover
cleaned eveything under the bonnet with gt85
removed the faulty exhaust manifold ready for its replacement
sanded down some rust spots,treated with inhibitor ready for skim and primer
now waiting on parts ....
SORNed the 1 litre and did some more swearing at the Audi.
Thought about fixing it.
Yeah i'm too scared to do anything to my polo incase i fuck it up or something because i love it so much!
Even washing it takes great care, never know, water might just leak through the windows seal... and flood the carpets leaving a pool big enough for a child to swim in... or was that the rain?
DROVE IT ;)
DROVE IT ;)
Oh and put red x in it
This thread is for the purpose of telling others of what you have done to your Polo today :thumbsup:
picked it up... polo coupe mk3! once i'd got it home gave it a wash and polish!:)
