Boot Wont Open
my boot wont open and will only open if i pull the bar , it is rather annoying anyone got any suggestions??
  • Views 927
Pulling on the bar? I recommend you go home, sober up and try again in the morning.
whats so bad about that? well u got any ideas einstein!? go back to the post office postman pat!
If its a mk1 -3:
You will need to dismantle and clean the whole lock mechanism (a long job with lots of small parts), or try spraying loads of dismantling spray into the lock and turning the key to see if it loosens.
Or buy a whole new lock mechanism.
Woah it was a joke dude chill your beans.
If you mean the rod from the button to latch then as Cymro says spray some lubricating fluid around it, and make sure that's it's not kinked or bent, and it's operating as it should.
If it's not that then next easiest is a replacement from a scrappy or something.
also owning a sonic bath makes life a lot easier, just remember which slot each slide came out of or it will never work again. :lol:
