Replacing Felt Door Strip On 6n2 Gti
hey guys
Picked up a tidy 6n2 gti from bristol on wednesday and theres a few bits i want to replace. I dont know what the part is called exactly but I'm after the rubber/felt strip that runs above the front doors down to the bottom of the windscreen. Anyone know the part number for this? I did get a quote from vw for 1 new strip which was £98.41 :-o
Will any felt/rubber strip from a 6n2 fit? And its it fairly easy to do?
Cheers fellas :-)
  • Views 816
I'm not sure if 6n's have them or not but I'd they do then they would be the same.
And yes 6n2's all use the same ones, only difference being if it's a two door or a 4door.
You Gould also try breakers yards as £100 each is very steep, and I think they just clip on .
Mine look like a mouse has eaten them, but they don't leak so I haven't bothered with them, but I did think of cutting them down abit so they would still seal but would be a bit shorter.
HTH
Yea thats how mine look :lol: Pretty straight forward then, I've seen a few 6n2's breaking so ill just go pull a couple off a scrapper. When the parts guy at VW told me £98 each i was shocked and just turned them down. He then tried to lecture me of the perils of a leaking seal but mines not leaking just looks abit gash.
Yep, he will try to get a sale, especially for a pOtential £200.
I'm sure that these don't actuall allow water into the car they just. Handel it down to to scuttle panel, so not really that essential, but for a few quid from the breakers it's worth it.
