Mk 2 Outer Sill Replacment
Hi guys
My mk 2 all though very solid is starting to show me where the rust is starting to get to it, mainly the drives side sill at the filler neck area and the front of the sill where ita been jacked up on the lip of the sill.
Iv got a lot of attachment to this car so dont mind spending the time/money on keeping it in gd nick spot I'm planning on trying to replace the outer sill, has any here done this job? On a polo or any other car it all helps
I can mig weld so the welding Shouldnt be a problem but I'm a noob to this kind of work on cars so I'm gratefull of any help:)
Kyle
Edited by Richman711
  • Views 853
yeah I have.. kinda! if you have a look in my build thread there will be pictures :)
Just be careful about the sill you get as lots of them are designed to fit over the exsiting sill rather than replace it. But depending on how bad it is you might just be able to use some sheet metal an make up some plates..
dont do it with the car jacked up funny as it might twist with the sill off ...pref on the wheels or axle stands near the wheels so it sits right
tack it on or use self tapers then test the door fits rights and closes nice before welding
Edited by steveo3002
