Does A Mk2f Polo Have A Low Fuel Warning Light
Hello
just wondering if anyone knows - Does a MK2f Polo have a low fuel warning light
thanks
irishkeet
  • Replies 25
  • Views 2k
Yes i'm pretty sure mk2's do...
Nope.
I use the little line above the red as a refill warning.
No.
When my Facet fuel pump starts clattering after corners, i know it's time to think about fuel..
Same as above mine was stripped an could here the fuel pump so knew it was nearly empty
No light
ahhh
I'm glad I asked I was waiting for the light to pop on before filling up, best fill up!
many thanks
irishkeet :)
The fuel pump gets right noisy. very shortly before total lack of fuel, it'll backfire like a bitch as I've found out afew times :lol:
mine never back fired or became noisey the fuel needle rises slightly with the vacuum in the tank thats just before its bone dry
mine backfires a little bit ,but as stated earlier the little notch in the red is when mine runs out (as it gets to bottom of notch ,so i fill up b4 it gets onto red usually
When my needle hits the top of the red I've got about 30 miles left. That'd be where the light would come on I reckon. Mine stops just above the bottom of the tank, halfway down the red.
I swear I had a fuel light in my old 1.3 NZ? Might just be me tripping out though...
the problem with mine is the needle sits between quarter and nothing for ages and then runs out! doesnt get to the red! think i might need to adjust the thingmee in the tank.
could a light be fitted is what I'm wondering though? have a LED on the dash that comes on when the fuel level gets to a certain point.....
My gauge is well good, does about 100 miles on full before it considers going down
How easy would it be to wire a light in? lol
There's a few redundant spaces for LED's in a MK3 dash.....
How many tobys does it take to fit a lightbulb....
Why not just illuminate the fuel guage?
I don't think it would be too complex but I'm not sure where you would get the signal from so that it only came on when fuel was low. I've always wanted one for the lights to complement the full beam warning light.
That's a damn good idea.
I want a light though
What kind of switch do cars with them use? Could just bodge something on off another car maybe, i dunno :lol:
I don't smoke mate, soz.
my electrical (non audio) skills are lacking but surely when the gauge gets to a certain level, a microswitch/relay could be triggered to light up a LED on the dash?
the whole system relies on resistance to work so all you would need is find the resistance at say the white line above red (on a mk2f) and work out a way of triggering the light at that resistance. and as our mk2fs have a blank where the diesel glow plug light would be it could be fitted there.
Using a transistor, and two resistors (once as a failsafe), and a variable, you can vary when the light comes on, so you can get it accurate.
Variable resistor, Rv = square root of (Rmin × Rmax)
For example an LDR: Rmin = 100, Rmax = 1M, so Rv = square root of (100 × 1M) = 10k.
LED Lights when it's dark.
LED Lights when it's light.
Wouldn't be too hard to mock up. You only need a feed, ground and a tank resistance feed. All at the clocks.
Edited by Adam-
I'm assuming you have the tank feed instead of the LDR? :lol:
The Golf beeps at me, i think three times, when the light comes on. Quite handy, because the steering wheel gets in the way of the fuel gauge even with the steering wheel all the way up.
I can see all the instruments/gauges perfectly in the Polo though. Progress fail.
I want a pointless led light too. Oh wait nah effort
