Knocking Noise With New Wheels
Fitted some new wheels today.
There is now a knocking noise from off side rear.
I have changed the bolts around so that the extended ones are on the front to accommodate the spacers on the front and the standard ones are on the back so I cant imagine it is the bolts.
Any ideas?
  • Views 680
Any ideas?
check the simple things first.
all wheel bolts tight enough?
correctly centered on the hub and fitted flush?
catching on an arch liner or suspension strut etc?
Any ideas?
Turns out one of the bolts is slightly different and the shoulder is more tapered so I think its just poking through the rear drum
