6n2 Wing Mirror
can you take the cover off?
  • Views 949
Yes, the first time it needs a bit of encouragement but from then on it practically falls off
Should be one screw to undo from the bottom, take that out and price the cover off with a knife between the black part and the cover from the middle
It's easier if you angle the mirror down so you see the floor, that way you won't rip the mirror off withy he cover, and you can see the clips inside.
HTH
