Seat Belt Tensioner Locked On
right so this mornin i hit a huge pothole i didnt see and mi front seat belt tensioners have locked on i cant get them to go in or out can anyone help me or do i need new seat belts?
thanks
  • Views 952
Sounds like its triggered the seatblet pre-tensioners thinking it was an impact. It might well be a case of new seatbelts I'm afraid :-(.
I'm not sure how you would go on in terms of coding the replacement belts on a 6N. I know from my experience at work, all modern cars require SRS safety systems to be recoded to the existing SRS control module or even a new module fitting after deployment of airbags or seatbelts. On older stuff, you may be able to get away without.
The 6n wouldn't have pretensioners, they do have interim reels and these may have got tangled of the belt wasn't put back right, you could try taking them out and releasing it but it's more then likely they won't come apart in such a way that you coul put them back together
Hth
