6n2 Gti
hi all! i have just bought a lovely low mileage 6n2 gti in black. but there is one or two issues, the main one, being my fault. the window glass has fallen off the rails, and i would like some advice on how to get it back on, is it a big job? and what steps should i take to ensure my windows doesn't shatter?
thanks!
  • Views 1k
The plastic clipS holding the window to the runners in place have no doubt broken.
Easieser to get the door card off and have a look. If they are broke then undo the 10mm bolts on the metal parts that connect to the window and remove them, then pull the window out the top and put somewhere safe. Then there are 4 or 5 10mm volts holding the mechanism to the door, undo these slightly and dis connect the electrical connector the lift and remove the whole thing and put it on a flat surface. What I usually do it use a thick shOrr screw and a cup or large flat washer and place the metal brackets on the runners then screw it down using the hole already in the centre of the clip.
What this does is stop the bracket failin off, you could even use silicone or similar to stop it moving around. Then put the mechanism back int but don't tighten the bolts up, then sit the indie in the bracket and raise the indie slightly then tighten up the bolts then lower te window until the brackets are visible though the holes then tighten they while pidgin the brackets up so it sits right.
Should work great after that, but allow a few hours to do this.
Hth
cheers for the help dixy! i took the door car off with a mate, and we came to the conclusion that the regulator is broke. took it to a friends garage and he confirmed this, rather annoying not having a window, but it happens to everyone i suppose :) . but once again, cheers for the help
Hi! Sorry, I can't help, but I've also just bought a lovely low mileage GTI in black! Lol! I picked it up on Friday July 27th! Collecting a few bits for it at the mo! Any plans for yours?
well, the windows all getting sorted today, then going to service it, clutch and lower arms. once all that is out the way the coilovers will be ordered, and looking at what wheels to get, not too sure yet lol. you? oh and i need a new cup holder lol
