spraying the bumpstrips
side bump strips on my 02 polo are a weird texture there bubbled/rough not smooth they haven't been modded they just come that way....... will these be ok to spray or do i need to buy new ones from vw or will they be the same?
  • Views 716
Their are a few threads on here where people have sprayed them with the rough texture just key the surface properly couple coats of plastic primer then few coats of colour then a few of varnish(or whatever its called I'm tired and cant remember)
preparation is most of the work get the bump strips properly clean then key them clean them till you think they are clean then clean them again(lots of cleaning)
best of luck and put some pics up when you are done :)
Yep as above, the prep is key, the cleaner they are the better they will turn out.
You could slightly sand them flatter, or just spray a coat of plastic primer/binder then if it's not smooth after that then use either shift build primer or a few oats of regular stuff, then a few light coats of paint (LIGHT being the goal here) then a few coats of lacquer. It key to mask up well aroun the area before hand, a the overspray will deffinatly take longer to remove then it would take to mask up.
Also if you car is a metallic colour (not so much black or silver) the colour match may not be good, so you may want to get it smooth and primed then get a body shop to paint them.
HTH
