6n2 heater controls not working
Hi guys,
I noticed the other day that my heater controls werent working. The direction (where the air goes i.e. in your face, on your feet.) doesnt seem to like facing outwards on the top vents i.e. face! the blowers blow down on to your feet, against the windscreen but not through the dash vents :(
The dial is quite hard to turn at certain points between foot and windscreen, generally in the middle of the both.
Anyone got any ideas on what to do?
  • Views 2.7k
Anyone????
Sounds like the cable has come off at the back, mine did that today on the heating setting, it's just a bitch to get to tbh.
There's two cables on the vent side. If you pull out the little cubby above the dials (it just pulls), and then the same for the surround on the controls. Wiggle it a little, it'll come free.
Remove the 4 screws holding the controls in place. Lift the centre console up from the back (it'll unclip), and lever out the handbrake surround bit. You'll see where it catches. It just pulls up too.
There is little bolts at the top of the console, hard to get to, I ended up snapping mine in anger so it doesn't quite sit right. You should be able to get a hand in and see the problem, the cable clips in and then goes onto the control.
Hard to describe. Talk to Nigel, he might have a diagram..
ah right ok.
Will have to have a gander at that tomorrow them :)
So are we talking like taking the whole centre console off (including gear stick etc.)
Thanks for the advice too :)
Well, I did it! was a bit of a ball ache getting the centre console back in and married up... well infact I had to take some additional parts of dash off to get it done LOL!
but thanks for the help dude!! I know have fresh air to my face! :)
Tell me about it! It's an actual mission to get that bit off, horrible job.
Glad you got it sorted though man! :)
