Some 6N2 GTI questions?!
Few small questions! I’m new to Polo GTI’s so don’t know as much as I do about mk.2 Golfs!
1.) Does the black textured plastic base to the wing mirror housing separate from the painted part that houses the mirror? The painted part of mine is fine, but there is a scuff on the black textured part that is bugging me.
2.) Did any of the rear seat backs come with carpet on the back? I just bought a good condition spare seat set and this set has grey carpet on the back, but most I’ve seen haven’t had the carpet. If it isn’t a standard thing, it’s been done well!
3.) Are mud flaps for 6N2 Polo’s the same as 6N Polo’s?
Think that’s it for now, but I’m sure there are other things! Lol!
Cheers for any help!
Edited by Aquablue
  • Views 840
about the mirrors, yes you can seperate them
Thanks. What's the easiest way to separate them?
Oh, another one I've just thought of! On the GTI badges, is the red in the 'I' of the GTI badge, paint/enamel or just a vinyl etc sticker?
just looked at mine, badge appears to be a red enamel insert/sticky thing!
haven't heard of carpet on the back of the rear bench :/
look underneath the wingmirror, should be screws!
The badge can be keyed and painted with a small bush and steady hand, or just replace it.
The mirror just pulls up and separated, first angle the mirror so you see the ground the prise it up gently, it will come off.
Some seats did come with carpet. If you want just the carpet then peel it off and use contact adhesive to stick it to your current seats.
Afaik the mud flaps are different for the gti as they have wider side skirts I think, but I'm fairly certain they are different to the 6n.
HTH
