breadvan seatbelts
Hi all,
Just wondering if all the seatbelt fitting for a mk2f breadvan will be the same as the coupe.
Have none of the rear seatbelts and would be a lot easier if i could use the coupe seatbelts.
Cheers,
Matt
  • Views 723
yes m8 the front seatbelts are the same on mk2 polos and mk2f polos in all the shapes . just make sure that the seatbelts go on the right sides or they will lock on you. they should have an L or R on them .
hope this helps .
if its the back two that you need i've a set from a breadvan that you'll know will fit . but from Northern Ireland and would post for you
