interchangable interiors
after some door cards for the breadvan (87) and was wondering if the mk2/3 coupes & breadvans would fit as a direct replacement with maybe useing later handles and so on? any thoughts please?
  • Views 919
Door cards are diff, and i think the inside of the door on a mk2 is different
The dashboard's longer on a mk2, so mk3 cards will need some adjustment* to fit. The door shell is the same, the only difference is later ones have side impact twigs.
*Damp the card down and slam the door.
Got a full mk2f interior in my mk2, pretty much all bolts straight in other than a slight bit of modding needed on the steering column
how different is the mk2f dash wiring compared to the mk2 dash wiring, what needs changing I'm thinking about swapping my loon dash board
