Bolt on pedal things
Yo000!
Wanna stick some Motorsport/boy racer bolt on pedal covers on my mk3 as I'm missing rubbers and such and it's another little mod to do.
I know there's rules on how close the pedals can be and such, so don't need advice there.
Had a very quick look yesterday,
The kits I'm looking at (sparco as I know the UK agent) seem to have bolts down the centre to hold them on.
Quick look at the mk3 pedals, the clutch seems to be welded offset so that's ok.
The brake the lever arm seems central to the pedal surface where I'd bolt to so the bolts wouldn't be able to go in the centre?
Anyone else fitted these ? I suppose i could offset it slightly but if the plate isn't much bigger than the pedal the offset may show edge of the original pedal and mess up the distances between them for MOT and such?
  • Replies 8
  • Views 992
i think :lol: , i have a set of those somewhere if you need some piccies ? and your inbox is full
I know what they look like lol, I just dunno how to mount them cause of the pedal lever arm, didn't know if anyone had an amazing solution.
And I know it is :) don't all have as much storage as you
Best bet I to use bolt on ones. You will need to drill holes into the pedals and you would need strong drill bits and a good drill to get through the metal.
Alternatively I'm sure vw sell ones that fit over the pedals on the same way the original ones do, as they have a river base beneath the metal. But they are probs pricey
HTH
Lol, I know to get bolt on ones, and that the pedals are fun to drill etc.
Been browsing about an just gonna get ones for brake/clutch where the two bolts are horizontal not vertical I think
I bought a set off ebay, can't remember the company (possibly Race Motorsport or something) but they were like a fiver! Proper quality cast items, thick curved chequerplate with bolts, only problem was they were yellow but a bit of Nitromors sorted it to get them looking solid.
Still, i then sprayed them matt black and flatted the black off the raised bits, then forgot to fit them and they're still in a box somewhere.
I wanted new rubbers, but i still have the pre-'86 brake/clutch pedals and can't find any. So if i don't like the feel of the ally's i'll probably find some factory's i like and weld them on with new rubbers.
I've got some carbon fibre looking sparco ones in the G. think i bolted the brake one on either side of the bar. I'm bored shitless so ill post up a pic ;)
If you do use these types of pedals MAKE SURE you bolt the brake pedals down you can stick the clutch and accelerator pedals on with chewing gum, but you have to make sure the brake is solid, and as above, if you can weld them on, this is the way to go.
What I'm trying to say is, the middle pedal is your lifeline, so make sure its solid.
