How do i adjust my door?
Hi all,
I'm fitting a new front wing onto my mk2 polo saloon. But i am struggling as it looks like the passenger door needs to move back I have tried undoing the 2 15mm bolts through the door hinges and lifting and pulling the door back but this didnt seam to do it any other things i could try?
Thankyou Mitch :-)
  • Views 898
Was there any damage to the old wing? As the mounting points for it may have moved and not the door.
Also it's easier to bend the wing to shape then it is to move to door to suit.
HTH
Yes the back end of the wing had been dented in towards the door stopping it from opening!
When you say the mounting points for the wing may have moved! Do you mean the ones running along the top of the inner wing on the engine bay?
Maybe i will have to bend the wing to get it to fit then spray it again as i have sprayed the wing and if i bend it I may crack the paint!
Thanks Mitch!
Yes, the mounts along the top may have moved slightly. Whenever there is movement in a panel, ie a dent inwards the fixings will wove outwards. I doubt the door would have moved though, unless the damage went thought to the a pillar?
Also withy the bending, if you fit it loosely ie put the bolts in , but do not tighten them then work the Wong into position as you tighten the bolts, should be very gentle bending and shouldn't damage the paint.
Also when the wing isn't tightened down it is very weak as mos of the strength is in the bolts.
HTH
