Mk1 Golf/Scirocco Running gear
I would rather sell as a job lot, Decided the break my scirocco due to engine problems. Everything I have got has done roughly 2000miles except the rear axle and calipers obviously. Bottom arms with ball joints poly bushed, Gsi front brake conversion with new discs, pads and goodridge hoses, Budget coilovers with febi top mounts, rear axle stripped and modified to run 3degrees negative camber and fitted camber shims to adjust the toe in. Backing plates painted with new wheel cylinders, shoes, drums, bearings, handbrake cables and that is also poly bushed. Got complete strut brace set the one in the engine bay could do with a coat of paint. I am located in south wales I would like £200 text me on 07983801662
Edited by BrydgeyCoupe
  • Replies 8
  • Views 218
For got to mention will also throw in a set of brand new steering rack gaitors and pair of new track rod ends and tierods. Dan
Sell the front coilies seperate?
Nah I can't sorry mate. If you purchase it all off me you can sell it on ;) I would post it on the mk1 owners club but I ain't a memba lol
will this lot fit a mk2 polo?
Mitch
Only the coilovers with modification
front brake conversion will, rear coilovers will but it will very low. rear brake setup may fit also.
Was thinking, this is ideal for a coilover conversion and some other things for a MK1/2/3, then sell the rest on or whatever!
If you split I'll have the coillies, need a budget pair for my rocco!
