getting back to bare metal
i look at all these builds threads and people remove large areas on paint back to bare metal what do they use to do it as i need to do it but the way i do it will take ages to do big panels
  • Replies 16
  • Views 1.8k
60 grit paper should do it lol
seriously tho your be surprised how quick that sort of grit will cut through the paint.
Just use finer grades as you start seeing metal so u dont ruin the bare metal.
DA
DA
Huh? Lol
Cup brush on the grinder.
Dual action sander - orbital sander - elbow grease - sanding block....
I'll give them a goo thanks:)
nitromors paint stripper - carefully!
what about underseal ie in the wheel arches
Blowtorch - carefully!
Hand grenade? Google?
paint stripper, scuff the surface with 80grit then apply it an leave for a while, it helps it cut through the layers better, dont leave it bare for long, why do you need to bare metal it?
not everywere but in places i need to because of rust its all good now tho got a dood way :)
I wouldnt use sandpaper will leave imperfections, on my mini i use special grinder discs not sure what they're called, they're black and quite thick bring it back to bare metal really well, such as this: http://www.screwfix.com/p/surface-preparat...bor-100mm/31074
linishing pad on a grinder, could do the whole car in an hour ;)
Nitromors is the fastest way but only ever seen it done on ratlook cars who don't want their car looking nice after.
Acid dipping.
