painting wing mirrors
basically i bought some 6n wing mirrors, they were the wrong colour
i sanded them back.... primed them 3 coats and left them to dry
now i put down a light coat of black pearl
left to dry
then a 2nd and 3rd coat however its like the paint is absorbing into the primer... as the black is disappearing after each coat of paint and being replaced by a dull finish ;/
any help would be appreciated
  • Views 646
left to dry
You've put the laquer on the top yeah? You'll always get a dull finish with the metallic/pearl etc and it's only once you've put the clear laquer on the top that you get the glossy/shiny finish. You don't neccesarily need a few coats of the metallic/pearl, it just needs full even coverage, but yeah 2 or 3 coats should do it-not any more than that. You'll need quite a few coats of laquer as it's that finish that you wet-sand/polish up and if you go through the laquer to the metallic finish, you'll need to spray the coats of laquer all again before you can wet-sand/polish up. When you wet-sand/polish up the laquer, make sure it's fully dry-say a day or two as if it's not, you'll have to go through all the stages again!
