Does anyone work (professionally) with car bodywork?
RUST!... is the problem I wish to tackle but it seems to be a real grey area.
I know it can be corrected because I had a surface rust scab on my VW Polo sill a few years ago. I had it repaired and it has never shown back through. Unfotunately I am no longer in touch with that bodyshop so I can't find out what method they used or which products either.
My friend will shortly be repairing light rust on my Bmw E34 bodywork and whilst he is great at the majority of prepping and painting, he isn't a proper bodyshop tech. and therefore he doesn't really know how to cure rust. Last time he repaired some rusty bits on my dad's Jag they started to show back through after 6 months or so. I believe he used Hammerite Kurust although was clearly not good enough.
What should he used in terms of primer or product before he applies primer? Zinc spray? Red oxide?
Let me know your thoughts!
  • Replies 9
  • Views 1.8k
I'm no proffesional but I've just done a few scabs on my mk3...
My POA was;
-Flat down rust and get as much out with the dremel with a metal brush attatchment on.
-I used Kure-Rust on it
-The Galv-Zinc primed
-Filled with filler
-Flatted
-High build primer
-Flatted
-Painted
-Laquered.
HTH!
Ok mate cheers, if i don't find anything else i'll tell my friend to follow this method.
it depends how bad the rust is tbh, sometimes it can look not bad at all but it could be terrible from behind meaning it would need cutting out and new metal welding in
I've worked at bodyshops all my life
the only method that lasts is removal ...so depending on how bad , sanding , wire wheeling , sandblasting , rust remover gel like deox gel , or if its bad replace the metal
in my experiance rust converting potions like kurust do very little
once its all cleaned back to silver steel use a etch or epoxy primer and paint it straight away , dont drive around with the car in primer for weeks
As Steveo says, removal is the key.
Rust is alive, a cancer, by chemical reaction.
The problem is metal quality - it varies, greatly. If your car is a rotter, it was made of shyte steel and you'll be pissing in the wind all the way to the scrap yard. So first you have to be sure you have a car made of good metal which is rusting less than most examples the same shape. Only then do you know that it's not gonna carry on rusting quicker than you can weld it! If yours is rusting too quick and you wanna keep it for some time, then you'd be better off doing a re-shell with an example that was made with better metal.
Sometimes you can put it down to age. The MK2 for example, most were at their worst in '86/'87. You don't see many solid 'D' reg examples and haven't done for many years (Karl has a solid one, rare survivor, so it's pretty special).
On the flip side, most '83s were almost stainless! But i knew someone in the early '90s who had a rotten one, so it's not that easy.
Nor is it easy with later models, where metal quality varied far more frequently.
So first, make sure you have a shell that isn't about to disolve, then cut out any rust and weld top quality metal in to replace it.
Ok guys,
Thanks a lot for the all the help.
It's a tough one, the E34's are mostly solid. There's still a fair few of them on the road and given some of them are like 24 yrs old that's good going. However, I have seen some real rotten ones on the forum too.
I'm fairly lucky, mine's solid, from what I can tell and it's only the bottom corner of the door and a scab on the back arch. The car hasn't got to be mint, although I would like it tidying up.
Will try etch primer or epoxy.
Many thanks
Ok guys,
Many thanks
if you find a good method can you let me know lol my 85 breadvan is in need of some rust repairs and iv been trying to find a good solution, and its good to see another yorkshire man on here :D were not that far away I'm in halifax
The etch primer is only there to prepare the metal for the build primer when painting bare metal, its not a rust cure. Also, don't srpay it onto filler as it can 'attack' the filler too.
  • 5 weeks later...
My POA was;
-Filled with filler
-Flatted
-High build primer
-Flatted
-Painted
-Laquered.
HTH!
what he said :)
