Polo fault codes and EGR
Hi trying to cure Kangarooing Polo 05reg 12 valve 1.2cc swapped coil packs replaced plugs, fuel filter, cleaned EGR valve with Carb cleaner, also cleaned throttle body in situ, slight improvement for 30 miles or so, but now wont accelerate, plugs sooting up, jet black and sooty but not wet, gave in and bought fault code reader off EBAY, 3 codes read 17811 16490 and 16891 anyone help with the first 2 codes that are not listed in my code reader book I'm thinking the fault lies in the EGR valve but according to Haynes manual if the EGR is replaced with a new one it has to be programmed at a VW dealers,anyone know any different.
thanks
  • Views 8.2k
17811/P1403/005123 - EGR System: Regulation Deviation
Possible Causes
Exhaust Gas Recirculation (EGR) faulty
Exhaust Gas Recirculation (EGR) Valve (N18) faulty
Possible Solutions
Check Exhaust Gas Recirculation (EGR)
Check Exhaust Gas Recirculation (EGR) Valve (N18)
Perform Output Test
16490/P0106/000262 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
Possible Symptoms
Erratic Idle
Possible Causes
Wiring and/or Connections from/to Manifold/Barometric Pressure Sensor (G71)/(F96) faulty
Leak in Air Intake and/or Exhaust
Engine Control Module faulty
Possible Solutions
Check Engine Control Module Software Version
See Special Notes for Details
Check Timing
Check Wiring and/or Connections from/to Manifold/Barometric Pressure Sensor (G71)/(F96)
Check for Leak in Air Intake and/or Exhaust
Check/Replace Manifold/Barometric Pressure Sensor (G71)/(F96)
Check/Replace Engine Controle Module
16891/P0507/001287 - Idle Control System RPM: Higher than Expected.
Possible Symptoms
Malfunction Indicator Lamp (MIL) active
Possible Causes
Throttle Valve Control Module (J338) dirty/faulty
Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
Vacuum Leak
Possible Solutions
Check Throttle Valve Control Module (J338)
Check Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
Check Intake System for Leaks
Edited by bartek
Possible Causes
Possible Solutions
Perform Output Test
Possible Symptoms
Erratic Idle
Possible Causes
Possible Solutions
Check Timing
Possible Symptoms
Possible Causes
Vacuum Leak
Possible Solutions
Thanks for your input regarding fault codes.
Polo eventually became totally undriveable so I had to tow it to a local non VW garage as VW couldn't even look for two weeks and I ran out of time,anyway local garage read faults code on their machine which only pulled up one code rather than the three that my Ebay reader found, which resulted in the Maf sensor being replaced to no avail,as car still wouldn't start,garage finished up replacing Catalytic converter which was apparently virtually blocked and exhaust system,Car now back with new Cat and Exhaust seems to be running Ok though exhaust seems to have a more sporty rasp to it, cant really understand why a cat should need replacing at 36,000 though or maybe that's what happens when a car is continually used for cold start 3/4 mile journeys.
