Best Way
Whats the best way to clean all the much and crap out of the engine bay as u can see from the pic is dirty and oily to hell and i want to get the metal work cleaned up too is it a case of taking it apart and cleaning it all in bits?
Edited by Gazzer2k
  • Replies 8
  • Views 1.2k
Steam cleaner?
Thinners or anything clean and volatile in a paraffin gun. Steam cleaning's overated and leaves condensation in your electrickery.
would that be any good on the pipes and the electric cables too?
worst areas with thinners as yeti says,then go over everything with gt85.
keep spraying the gt85 well on to a rag and wipe over everything,avoiding cambelt/aux belt.
not only will it be clean and shine but will also be protected from moisture.
might try and dig out a old windowlene bottle lol and some scourer pads and some elbow grease
could you use something like white spirits, il have a google and look at that gt85 stuff
Google it mate,its good stuff
Similar to wd40 but more oily.great for cleaning the bay.. :-)
yeh had a quick look halfords £4.99 might pick some up
I like it, can use it on all sorts - even your leather trainers!
It contains teflon, see. It's a protectant. It's not so much an oil as a 'dry' lubricant.
