Mk2 loon
Hi everyone been itching for a polo since I sold my mk3, anyway local one came up and went to view it Tonight but need some advice, it's a darkish blue mk2 loon, 1.0 5 speed, 79,000 mot till November,rust I'm the inside drivers door, ( are doors same as a coupe or mk3? Also clutch is very heavy looked at clutch cable and looked very dry, exhaust is blowing, And there's an oil leak somewhere in the bay ,basically wanting to know ig it would be worth it? I would plan an afh or gt ( how much is a conversion roughly) and fix all those little problems, cheekily offered him £160 and he accepted ( should of offered 100 lol)basically wondering if it's worth doing all the plans and how much roughly to fix problems conversion and lows :) only took one cheeky photo but can't upload ATM :)Cheers
Edited by Jake Ellis
  • Replies 15
  • Views 1k
Replace the clutch cable to sort that problem, i it is the cable -£15
Oil leak doesn't really matter as your changing the engine although every mk2 i'v had has leaks above the alternator.
Doors are the same for mk2 and 3 so easy to find
Exhaust blowing is a matter of checking it all tight and applying some exhaust paste.
£160 seems a bargain. I'd snap his hand off if that's all that wrong with it. Does it have plastic arches? May be worth poking about inside the arch just to make sure rot hasn't set it there
It does have plastic arches :) already checked there, battery tray, filler neck, literly that's the only bit of rust on door! P.s fuck me no power steerings effort lol
Nice one. Oil and exhaust leaks are irrelevant if you're doing an engine conversion, surely? Same with the clutch really, as you're gonna address that too.
Doors are the same fit, you'll need to swap the trim over and that can include windows/seals. Plus the paint issue, of course.
Whether it's worth it or not is a matter of opinion - if you like the feel of the car now, then you imagine it with treble the power, well then what do you think..?
Tbh was horrible to drive! Clutch really was that tough! Haha and steering seemed very very heavy
GET ON THEM WEIGHTS!
:crybaby:
No Simon there's a non power steering car then there was this! Haha my mk3 was like 6 times easier!
sounds a bargain and a reasonable project. Good luck with it. Nothing too serious there from what you have said.
a afh or GT conversion can vary in cost from nothing to about a grand depending on how you go about it.
mine in all probability is going to cost £500 ish, but I could do it for £250.
Edited by Retrotub
Could just be the tyre pressures, grab a gauge and check those out. To add to the doors being the same; I'm sure MK3 doors have side impact bars where as MK2s do not.
Yeah might of just been tyres! Hopefully picking up tomoz, sweet cheers for heads up tub
More like a side impact twig! :lol:
The doors are identical apart from this and outwardly the same.
Only the later mk3s have SIBs just to add.
if thats all thats wrong with it then you can't really go wrong, even if it turns out to be a shed you could sell a few bits off it and weigh the rest in and still make a nice profit :thumbsup:
what you've listed is all easy enough to sort tho
Cheers guys :)
Buy your mk3 back from me!!! if this doesn't go through of course...
If its not fucked bro!
