replacing 6n sills
I'm looking to replacing my complete sills on my 6n due to patches of rust.
I want to know whats involved??
How do i remove old rusty sills??
I think by arches at the ends the rust is behind sills aswell, how would i sort this out??
Are new sills welded on or fixed in some other way??
Any help would be good....
Dan
  • Views 1.4k
The sills are welded on, they'd have to be very bad to justify having the whole thing replaced.
The sills are a structural component, by complete sills are you talking inner and outer or just the outer? When doing structural work you should really brace the shell to stop it distorting.
Personally i would chop the rusty sections out and then using sheet steel make up new sections.
I was thinking of just the whole outer.
The rust is around the join in the middle of the sill and then at the rear end by the rear arch.
Also iv noticed the lip underneath that the OE jack sits on is rusted along the whole length and every time i jack the car up bits are breaking off or bending over flat....
I dont really know what the best thing to do is, it was all picked up on last mot aswell so worried it wont pass next time because iv done nothing to sort it out....
the shell won't distort when replacing sills
agreed, the shell wont distort by replacing the outter sills, without knowing or seeing the full extent of the rust i would advise going somewhere that can hep you out, if you cant weld then theres pretty much nothing you can do yourself and to get the job done correctly could be quite costly, try asking youself the question "how much is it going to cost me? how much is the car worth? is it worth spending and doing?"
if the sill lip is going to need work the the bill will prob double due to the level of work involved and time taken to strip the car ready for welding.
i would personaly be weying up my options as rust can be like an iceberg,its usualy twice as big under the surface than it is on top so theres no telling what its going to be like underneath.
I'm not trying to put you down just speaking the facts from experiances through work
