Log book details
Afternoon all just a quick question last year I took all my stuff out of my g40 and put it in a better shell.the shell I transfered everything to is an original g40 shell but hasn't been registered as one.I've made phone calls to the appropriate people at Vw and they have confirmed that the shell is indeed a g40. So the question I ask is can I change the details on my logbook so it is registered as a g40 and if so,how do it do it many thanks Matt
  • Views 718
In b4 paperwork section..
So you've changed to the book/plate/vin of the new shell, and the DVLA have failed to list it as a G40 on it's own book? Well then perhaps their records didn't show it as a G40. If you can get paperwork proof that it is a G40 shell then it might be worth sending that to the DVLA with an enclosing letter? That's what i'd try.
Or you've kept the original identity and reported a new shell, then they've stripped your original i.d of it's title? Could be a mistake or missing info on their part, but could be that there's a reason they've omitted it. I don't know about that but it seems unlikely if it's only the shell that has been changed, you'd find out though their response sending the letter and certificate all the same.
I used the i.d of the replacement shell, seemed safer and easier (even though it had a crap registration number!).
just to add, i would only send copies of any paper work. the DVLA are shit at not losing paper work
are you basicly saying you've re-shelled your car? if so i believe the correct way around doing so is to take the old vin tag out of your car and you must attach it (either weld or rivet) at the side of the one in your new shell, if you get rid of the id on the new shell and just put the one from your old shell on then that is classed as ringing and can get your car crushed, you've to send a pic (possibly have to take for a vic check) and a written letter to dvla and they will update there recoreds, i believe it will show on you log book as it having a reshell or having details of another shell, but in the end the car will still be registered as a g40 if that is what it is. i may be wrong about a few things but this is what I'm led to believe from some people i know in the body trade
The old one was a g40 shell and the current shell is also a g40 shell but for some reason it is a genuine g40 shell.vw have confirmed this and there is a sticker in the boot stating it is a g40 but it was registered a a polo for some reason
