Harris' MK2F CL Coupe
Heres an at the wheels graph, saved a couple to my memory stick but not how I wanted lol. this is wheel HP.
Will give max something to analyse and inform me of wonderful book quotes xxx
  • Replies 168
  • Views 36k
  • harris.racing
    harris.racing
    Hi all, massive update, well overdue! Don't really know where to start...life has been in the way a bit, some 22 weeks out of the UK last year, bought my first home etc, but hey ho! Cant really reme
  • harris.racing
    harris.racing
    Stripped down a steering rack today thanks to Steve, now I know how I'm going to reduce my steering lock I can crack on with that, just need to work out what size spacers I will need to reduce the loc
  • Your just too amazing thats why nick
Looks nice and smooth tho nick?
nick man, thats some seriously good power graph.. so flat!
I was guna say that 120 rr surely is unbelievable with the time on pod. Looking good pal.
I have a V5!!
Just put 12 months tax on... £220! :(
Not sure if I can drive it under the 5 days grace as Iv taxed it after its expired??
Actually decided to do something..
Got this..
1B2FA8C0-8695-4A85-974D-BDA10B11D623-241
Left coilpack and TPS at my friends but yeah.
Going to make a new loom, probably just buy new connectors and pins: apart from the EDIS module - connector is 40£!
Awaiting a crank pulley from Mr runforrestrun then I'll order a trigger wheel and make up a bracket for the crank sensor side of things.
Then gonna machine a dizzy blank and also mount the coilpack off this, adapt my HT leads to suit the ford coil pack connections
Bit of an update again:
Found some different front springs to try, longer free length and slightly stiffer, extra length isnt an issue as I have plenty of adjustment left to take it up.
0E11E644-0916-4106-BEEA-A551222376F3-865
Also got some more MJ bits together,
OEM Ford later style 4 cyl coil pack & a CBR 600 TPS
I have used the CBR TPS with a megajolt setup before and worked a treat, so no issues there.
Will need to change the ends on my HT leads to suit the coilpack, but thats not an issue.
0E42EFA4-9347-41DD-AEFA-FB3766AA8CAE-865
D8B82A1D-893C-4CEE-98F2-8F07CF7311C7-865
Need to order up some new connectors and such.
Going to be a bit of a faff trying to sort this crank sensor, may well need to be mounted on the back of the block, but need to check clearance to driveshafts.
Need to measure the offset difference of the earlier 'V belt' type pulley to determine where to mount the trigger wheel.
Also got her back to life and took her for a drive yesterday, and decided to give her a wash. Paint is really porous it seems and it seems to stain easily which is rather annoying, need to try and find a really oily wax/polish/sealant.
719B32EB-9882-4747-BD6A-9AEBFA54B464-865
98A3EA4D-2CD8-4F95-B8AD-D3B1D305C740-865
1846077E-470A-4590-A672-419EBB4EAADC-865
Will be playing with ride heights and corner weights again once I have swapped springs and such.
Other than that, I need to make up the MJ loom at some point, but this can wait.
Priorities for the MJ are mainly sorting the trigger wheel setup, and machining a blank for the dizzy, which will also have tapped blind holes in it to mount a bracket to mount the coil pack.
Will be fitting black carpet when the seats are swapped, the rear interior will be stripped, but I will still be retaining a dash/heater/openable windows etc.
May also fit perspex/lexan side windows to shed a bit of weight too.
Be interesting to see how the MJ behaves on the AEE, I still want to build a 1.6 16v, not sure on a spec, and the AEE may become boost ready when a valvers in the car, but at the moment I'm still interested in tinkering with the AEE in its NA form as it seems to go well and surprise a few people.
  • 8 months later...
Just given this thread an almighty clean up, deleted 15 pages of shite basically!
A lot of posts between things were deleted, so apologies if some things dont make sense!
Needs an update, might do it today depends how photobuckets playing AND if I can even remember what I have done between now and the last update!
Awesome thread dude! Love the look of the bay, much prefer that to all the smoothed and tucked nonsense!
Right, deeeeep breath now.
So I didnt really do anything after GTI Fest, went for a hack on NYE with Jamie ..
f112389de5389d01c59765765bdbe29e_zpsef40
Then went RR day..
603074_10200669013193482_1076953227_n_zp
After that, I set about sorting the megajolt out, and tidying up my engine bay.
So I started by getting the trigger wheel sorted, this involved changing to the earlier V belt type pulley for chassis leg clearance.
Machined myself a hub-centric spacer for the trigger wheel to sit on..
This was to clear the dish of the pulley.
Messing around for clearance, mocking up a crank sensor bracket...
fd598df1bb122714985be0ada5aaf75c_zps493c
Also machined myself a blank for the distributor, and made a bracket to hold the coil pack..
73caf3546af9a1cb794515392bac7c7e_zps3152
e6749a43efd6c988f3f76de282eefb40_zpsfac5
I then decided as I was going to be redoing some wiring etc, id tidy up the engine bay and a few other bits and bobs.
So started taking stuff apart/getting rid of stuff
a3755c9fcbbc90f1b0101ccafb8da51e_zpsb84d
5bb10315b6d6e3294a47dde35b534368_zps1297
cace6fdb98122157444c008dde1fad60_zpsc5f4
Bought a smaller washer bottle and set about mounting/hiding it..
268c1d4df8021f380ab939ba9c2db764_zps81a5
4496ae4070947e705f450573374f659d_zps1620
Next up, wrapped my 4-2-1
8b80def1440b530a1644792d72705965_zpsd45a
8cd8b45a305a868345418c80a19d038b_zps95e4
Cleaned under arches, gave wheels a good clean/wax etc
b0b7bce1abe7883d5c129fbd110f2802_zpsd691
e02cfe3eb24cf424d40234cdd4715e2b_zpsafc8
29f0bb9034efe5e5ed5c2f72b535ae04_zpsddda
''Refurbed'' my bumpers
3255177ccfe63a7bfcddd0f8724ddec9_zpsd503
5be70a55e0e121406ef02dbe95516355_zpsf4a9
Set about getting wiring sorted and the megajolt installed..
723a2902d168989156246ac2e472328c_zps7ff7
fad59bfac55d4cfa2a874a6cc225395f_zps69e0
c36af9e40fb7998beb0bbe33339701c6_zps7e3a
5cb2b700b2d31649e78b493b0727513e_zps812c
1044a4ca261e46534f2efe89cf3bcf14_zpseb23/6486255dde283b041331de29f2aec925_zps05587b74.jpg.html]6486255dde283b041331de29f2aec925_zps0558[/url]
298f21c3eb7f813e2735a136bece3187_zps4233
Rewrapped and rerouted standard loom..
581ce234caeb25560aacc7bc30b4e97b_zps7044
All back together..
83f068acbac1a7620f88917312751ac1_zpse379
28ae3776b76ab47180b30dd19f8a2449_zpsc7b8
7b6ebd1a541e58bfcbb61f22064319b3_zpsca90
Had a few teething problems with the megajolt to begin with, but got it all sorted.
I have not mapped it properly (or had it mapped) just did a bit of tweaking on some supplied maps with a friend one night, its noticably better through the range. Well worth it.
Took it to a RR with my mates mk1..
51c337bfb4476dc68a672d538580e186_zps3f4b
0ece5d3dad48c186eabc382d83b7a510_zps777f
Heres a graph to compare dizzy vs megajolt, much better through the range, still the same peak power but torques improved massively.
calculatedfromtorquegraph_zps5716176b.jp
Also decided I wanted some shorter springs to get slightly lower, but this would mean they wern't retained at full droop, so got some super slim helpers too ;)
a3e2b3ad0926454f38865438f32fe9b8_zps72d5
6bb8a3452393ad075766b6931f6d9b5d_zps7005
At some point I also got a Momo Team 300mm, some pedals, changed carpet to black and got a new AFR gauge lol :p
75b7e2d768115993bee17b5a75350275_zps5d5e
Next up I believe was GTI Spring Festival at pod...
They kinda forgot to set us out a club stand :thumbsup:
Abandoned half way through day..
On the strip..
Managed a 14.9 again, but there was an epic head wind unlike at Autumn Fest, and I dont think I hooked it up as well as I could have done, I'm pretty sure a faster time is capable with the megajolt for sure.
Next thing I believe was Stanford Hall, nice chilled day out...
Thanks to whoever took this pic.. love it..
Also, 8v mates..
So after Stanford was the track day at Cadwell park, set out early with JamieDub y0 at like 4.30am or something stupid... but hey I was excitedd!
Had an issue in the morning involving fuel not wanting to be in the tank, preferring being on my rear tyre, thus putting me into the tyre wall..it took some investigation..
..and further prevention!
Had a sick day once was sorted though! Had to raise the car up as was scrubbing, handling kind of went to shit but was still a laugh!
Max added some tape just incase I ended up in a wall again, thanks mate
LOVE this picture!
At the end of the day :)
Cheeky couple of videos, fifth was too long to go into really, and didnt wanna hang fourth out so easing off on the straights a bit..
Didnt really do much after that, got an MOT, headed to the Poloshow..
Show and shine..
Last to leave on the Monday
Oh yeah, EDIT:
Forgot at some point, also got some Rocco GT2 seats, which fit me AMAZINGLY, so comfortable!!
a4f121c69d4bfa9d205a9fc56c188517_zps403c
4cdd5bf16e6d1d4ab6537d586d255afe_zps29bd
Also got some speaker pods, they're all in and fitted now, no pictures though, sounds a lot better than 3.5'' dash speakers :)
90fa0c8402b9a937a7a2aaeb8bdcea2e_zps4b1c
Sorry for the massive amount of pics, and I hope this is a good read for some.
Future plans, I have some, not sure whats for definate or not yet, but I have a new engine in pieces which will be going in later this year or early next Id imagine, see what this EFI lark is all about.
Nick
You put so much effort in it shames me.
Great read! :thumbsup:
Rocco seats are great, really comfy and suit the car perfectly. Sweet car this!
Thought Id just show a quick comparison of things..
So this is the engine bay around Oct last year, and how it is now, so obviously tidied wiring, get rid of washer bottle, changed cam cover, you may have noticed that some fixings etc have changed to stainless - subtle things.
Then
4C4D37B8-8198-40FA-AFB6-3E74F9847DDA-739
Now
Plans wise, well I'm going to keep a bit quiet on that, spoils all the fun writing a big list of it all, however now I have a daily I'm relatively happy with,
5cc2327c270fb5eae73443b854812ddc_zpse177
..I dont mind compromising a bit more on this to make it suitable for track etc :)
Thanks for nice comments x
Loving the effort that has gone into this.
Quickie though how fiddly was it to fit those bonnet struts?
I have a set in a box but i havn't looked into fitting them yet thanks
Thanks mate.
And dead easy, just replace one of the bonnet hinge bolts for the ball joint thing and screw the other into the wing, may even go in place of a wing bolt IIRC
One of my fav cars on here now, looks great. Love the on track pick from behind!
Looked for this thread for ages Nick, glad I finally stumbled onto it! Really nice work dude, a proper clean well engineered polo!
Thanks guys.
Couple of random videos I have just found,
On RR after fitting megajolt (hard cut limiter is Lols)
http://s963.photobucket.com/user/harrisrac...733547.mp4.html
At Spring Fest, Q the wind! lol, a 15.1 here..
http://s963.photobucket.com/user/harrisrac...0a49fd.mp4.html
On RR at poloshow, just because..
http://s963.photobucket.com/user/harrisrac...498382.mp4.html
And speaker pods in the car..
e18bdf3af4a826eacf08aba5a2542996_zpsbf81
7a234cbbbd7df433b55245ec50b53838_zpsf566
Engine wise, got a 1.6 16v in pieces, well an AVY/AFH, gonna finish stripping that, and get some bits dropped off for balancing etc soon, also going to be ordering a management system soon, think I need around 250cc injectors, but going to hold off and see what fitment my ITBs are going to be first.
Couple of plans chassis wise too but all in good time.
& Tom, you probably struggled to find it as it was hidden, I spent ages deleting loads of stuff and reopened it :thumbsup:
Ah right cool man! I will have some cleaned and flow tested G60 injectors available after GTI fest dude as I'm upgrading to 320's, dont mind giving you first refusal :D
Edited by etches69
Well, 170hp @ 80% duty cycle & 3.0 bar fuel pressure is a 278cc roughly, so I'd imagine 250cc g60 ones be okay
if your buying new management id deffo be interested in the megajolt stuff
Thanks mate.
thanks i appreciate it ill give it a go
Shopping list engine wise:
Stuff for engine rebuild (shells, rings, tappets etc)
Machinining/balancing of engine bits
ITBs
Make inlet manifold
G60 injectors
Inline fuel pump
Pressure regulator
Blue temp sensor (anyone got resistance values to save me measuring?)
Inlet air temp sensor
GTI crank sensor & connector (anyone got an AVY one they're not in need of?)
Management system
Ignition driver
Map sensor
Throttle position sensor
Wrap exhaust mani
New custom exhaust
Gonna get back on this soon, have got a list of parts together, so can start ordering stuff soonish. Need to speak to my local engine shop regarding head skimming, block honing, balancing etc.
Need to see if g60 injectors will fit the ITBs I'm getting as they're off a bike I think they maybe smaller.
May run down the strip at action this weekend, hopefully less wind so maybe able to beat the 14.9 :)
I was originally going to stick with carbs, as IMO they're sufficient for what I will be using the car for, pretty simple to work with, and to be honest I have no reliability issues with them whatsoever. Coupled with the megajolt it would be a strong setup, however, a lot of other people are running carbs now, and there will be a couple of 1.6 16v's on them, so I'm using them just as its a little different, in theory better (not sure about peak power better) but drivability should be better (although with the variable Venturi bike carbs I'm not entirely convinced) and I'd just like to learn something new; I'm looking forward to tinkering with mapping and refining it, although this one will be going somewhere for a mapping session when iv got it somewhere near and I'm happy with it, to optimise it fully, which IMO the only real way to see gains is on a RR, I don't think my arse is sensitive enough to notice 1 or 2nm of torque here and there
Now your in the 14s what are you hoping to crack on the strip now?
No idea to be honest, the car feels a little odd recently, I need to get my laptop on it as the megajolt seems to be going on a weird one recently, it reads RPM & loading correctly, so let's say
20% throttle, 2500rpm should be 22 degrees ignition (not got map to hand, so just an example)
Which it reads correctly, but it will sit lower down the map and be at like 17 or something, even though it knows where it is.
I fixed it the other week but can't help but feel as though it's maybe gone funny again.
A 14.7 would be nice, but to be honest it's all about the launch with such little power, at the end of the day it's an MA 1.6 8v, it's already done better than I expected
