Wet feet....
Hey all.
Bought my polo today, and thought I'd treat it to a car wash.
So took her in, and as it came onto a rinse, the whole footwell filled with water, is there a drain?
So the other question is, how do I prevent getting wet feet again? Is there a drain in the bulk head or something?
Hope someone can help.
  • Replies 14
  • Views 1.3k
oh ohhhh! drivers side front? remove yoru battery and check for holes.... its not ment to be a drain but it sure sounds like its turned into one!
Oh fantastic!
The cars rust free other than the battery tray if it is that, that's gone. :-(
Looks like I'll have to dig the welder out...
Is it worth installing some form of drain?
Theres not alot you can do really, i guess you could make it more sloped at the back of the bracket when you come to welding but dont forget the battery has to fit.
If its been there 20 or so years like that i'd throw some good quality steel in and be done with it :-)
If you angle it, make the higher end closer to the cabin or you won't get your servo to fit
I'll just repair it as normal, be easier.
I'll take the battery out tonight and have a proper look.
There is a drain in the battery tray, three in fact, for the battery side there's a hole going through the inner wing allowing the water to drain down inside the outer wing and out the bottom past the arch liner.
It depends how badly its rotted, but you should definitely try and shape it so that the water heads this way, it also needs to allow water to flow along from closer to the middle too.
This is the damage.
11E27B89-BAD9-4BE1-8981-83B096A4AAA6-241
I had this on my breadvan, not as hardcore as yours, all i did was sand off the rust treated the area then got some metal putty and painted over it................never leaked since!
Mine looked like that maybe worse! Get you grinder out!!!
Think what I might do, if theres enough room, is put the battery one some stilts, so if water get in there, it doesn't get taped under the battery.
But I'll do all that when I get from my holiday.
I literally fixed mine today, welded a piece in and red oxided it all. its in my build thread dude
Where's your thread? :-)
Hmmm. That might be the better way to attack the rust too.....
How did you strip the dash out?
