Breaking Polo GTI 6n2 1.6 16v engine ARC
I am breaking a polo GTi ARC/AVY engine from a 6n2.
Engine was a very good runner until it started burning oil, suspected piston rings. This is a completely standard engine.
All partrs available except:
Alternator
Alternator Tensioner
Plastic Engine Cover
PM me, or ring on 07935480454
Liam
Edited by Bertman
  • Replies 12
  • Views 451
few parts to list:
Starter Motor - £20
PAS pump - £20
Air Con Pump - £20
Inlet Manifold - £35
Throttle Body - £15
Air Filter Housing - £10
Crank Pulley - £30
Crank Angle Sensor - £10
Cam Belt Covers - £5 each
All parts are in great condition and work perfectly.
Edited by Bertman
how much extra would postage be on the starter motor ?
PM'd
How much for the engine block. I dont need the head. Pistons would be preferable but doesn't matter if not. Cheers bud
PM'd
Most parts still available
hi mate, you selling the gearbox as well?
The gearbox has sold already mate.
Updated List:
Starter Motor - £20
Engine Block (Bottom End) - £50
Pistons + Conrods - £5 each
Crank - £20
Complete Cylinder Head (needs valve seals) - £50
Camshaft Cover - £20
PAS pump - £20
Air Con Pump - £20
Throttle Body - £15
Crank Pulley - £30
Crank Pulley - £45
plus plenty more: injectors, injection rail, sump, oil pick up, oil pump etc
Feel free to make sensible offers, willing to deals on bulk buys aswell
Edited by Bertman
bump
Updated List:
Starter Motor - £20
Crank - £20
PAS pump - £20
Air Con Pump - £20
Throttle Body - £15
Crank Pulley - £30
Crank Pulley - £45
Clutch mate?
Is it 3 or 5 door mate? I need some doorcards if it's 3 door?
