1.3 mh head on 1.4 bottom end
is this possible and what bottom ends best?. and what benefits would there be?
I'm going to be running bike carbs and would like to do a few more mods to the engine, cam etc etc..
what else would you guys would do?
cheers, joe
  • Replies 16
  • Views 1.3k
yes it bolts straight on
advantage would be the 1400 will have more torque
Ok cheers mate, any particular 1.4 block?
abd works
although i think id go for a 16v ..more power and not too much hassle
abd works
16v block? Or whole engine?
abd works
Whole engine, AFH code
If your set on keeping it looking original then the ABD bottom end, or full engine, the head is the same.
abd works
Yer. Just fancy havin a mess about with the 1.3 8v at the mo mate. I know people are gonna say why spend money on not much power but a 1.4 afh could only be run on bike carbs as I really cba to convert to ecu etc...
I also wanted a smallish engine as I'm going to be fully smoothing the ba and getting rid of everything into other places exept the engine etc.
put a 1.6 AEE in there. looks the same as a 1.3 pretty much!
Yer dude, what bhp are these standard and fairly easy to get hold of?
75bhp 100 torque, if you do some mods to them they pull really well!
He's got one you can have :lol:
perfect running order :lol:
yeah for future reference, make sure the engine runs first lol
Yer dude pret interested in this way then, I'd still run it on bike carbs what other mods is there for this? Cams etc?
yeah you can get a 268 or a 272 cam but you need a vernier pulley to get the timing spot on.
theres someone on here with one that made around 140 bhp with carbs and a cam
Sweet have to have a gander into that then, straigh bolt I jobby?
Also should. Use that engines gearbox for could I use my 5 speed off the 1.0l
you can use your 5 speed
bolts in the same way as an AFH so have a look on the conversion guide in the engine FAQ's
Ok cheers bud
