Mark2 saloon Formel E
All parts available, including:
70mm suspension kit with struts
Arch and sill trim set
Headlamps
Fuel tank
Alloy rocker cover
Gearbox
Glass
Bumpers
Lights
Headlights
1.3 SPi dizzy
Standard Mark3 coil
Astrali steering wheel (no horn push)
Saloon rear lights
Postage available on smaller items at buyers cost. Larger items collection only from Nottingham.
  • Replies 32
  • Views 2.6k
Exhaust, fuel tank and gearbox sold.
Roll up, roll up. any more takers?
Steering wheel still available? If so what size is it?
Got a choice of 2 sir.
1 Astrali without horn push for a small spline @ £20
1 Mountney with horn push for a small spline @ £30
Unsure on diameters, but on initial glance they're both around Coupe S steering wheel size, maybe smaller.
Can you take a tape measure to them? Just want to get an idea of the size. What condition are they in, the one in the pic looks pretty good but I'm looking on my phone. Also are the bosses the long reach kinda ones? Got a short reach one and it makes the steering wheel sit too close to the stalks
Cheers blud
Cheers blud
Hi Guy.
Measured them both up last night, they're both around 330mm, so standard ish Polo wheel size.
The Astrali one has a strange set-up on it, I would say it's similar to what you have now in that it sits closer to the stalks.
The Mountey one has a more conventional boss, but not what I would class as long reach.
Single lamp grille now sold.
Gutter trims provisionally sold.
What are the front and rear screen rubbers like? Are they plain ones? I wouldn't mind them if they are. :)
have you got the door card pockets and how much did u want for the alloy rocker cover
i now own the rocker cover so its really not available.
do you have a mk2 rear bumper anywhere? preferably a saloon one but not that fussed if not :)
cheers,
George
do you have the speaker grill for the front speaker in the dash
Hazard swirch Karl?
Completely forgot about this! We have 2 rear bumpers in stock. Saloon rear which you can have for beer money, as the plastic cover has come away from the metal beam. I've tried clipping it back, but suspect clips are broken. The other bumper is squareback. Yours for £20. Speaker grille, I can do. 2 in stock. Hazard switch, I cant do as that was used in the other loon.
How much u want for the speaker grill
A beer or something at a show. You going the RR day (I can't remember)?
If so, I'll bring it along then, as I struggle to post things out.
Cheers.
Cheers.
yuh a beer is fine with me and not wasnt going the RR day but I've just put my name down now so ill see you there if the saloon makes it there that is, time to find out what this saloon has been tuned too......
do you have a picture of the other steering wheel?
I'll need to get down to the unit where the parts are and try and remember to grab a pic. Both wheels are approx 330mm in diameter.
Even just one from google so I know what it looks like will do...
Karl, Still got the alternator? And does it all work?
Can't find it on google after an initial search. I'd be inclined to suggest its pretty old, hence why I'm struggling to turn up anything.
The alternator went a good while ago, sorry :-(.
I do still have:
Pair of rear lamps, not A1 condition, but useable
Full suspension kit complete with struts
Bonnet
Headlamps
Full set of glass
Full set of plastic arch and sill trims
Passenger window regulator
SPi injection stuff, such as coil, distributor, fuel pump and accumulator
Collection preferred as I haven't time to post.
Have you got the working heater blower motor? :)
Edited by Alexis
Loon suspension same as coupe is it? If so how much? And do you still have rocker cover and how much? Cheers
i own the rocker cover so not available.
