6n 1.4 16v ...
hi , I'm new to the vw scene and iv just got a 1.4 16v 6n , basicly its got a running fault - when i start it it will idle at 2k and stay like that for over a minute ... iv taked the throttle body off and cleaned it out and cleaned the contacts aswell , iv been told this could be the throttle position sensor thats faulty ??? anyone else had a similar problem ? it maybe something completely different but like i said I'm new to the vw scene and really need to sort it out !
cheers
  • Views 915
One thing id to pull thé egr plug, this is just in front of thé distributor.
Lève thé batterie déconnectés overnight. Once connectés, go for a little drive normales.
did you take disconnect the throttle body when you took it off? if so you may need to have it reset.
i disconnected the throttle cable, unplugged the switch and removed the body , cleaned it and put it back together , was still doin the same
Excuse my french.
is it possible that a similar thing was done for another reason by a previous owner and still not reset? a mate has an Ibiza that is doing the same.
i always throught throttle bodys needed coding to the exact car . otherwise your able to get problems
