MK2 Breadvan Bonnet
Hi all,
My Bonnet flew open while i was doing about 60 :s , it opened so far that i coulnt shut it, turns out that one of the arms that hold it on got bent, does anyone know how to remove them? i couldnt find a bolt to remove it or anything can anyone help??
  • Views 896
i think, they pivot on a stud thats welded to the wing, with some sort of clip that needs to be removed. Best off to grab a small mirror and a torch and have a look ;)
lloks like it may be a wing off job................Never done that before is it hard?
I can't see the wing making a difference, you won't have more access.
If you remove it, ensure you undo all the bolts before you try to pull it off. Some of the ones on the inside are covered in sealant, best way i found was to position the 10mm socket over the coach bolt head, then simply hammer the extension bar with a mallet to force the socket through the sealant until i'm through to the panel, then it's safe to twist the coach bolt without rounding it off.
pretty sure theres no fixings under the wing...get a torch and mirror and look under the scuttle
