6n2 windows
Hi guys, any one had any issues with there windows? Got a gti 6n2 and the passenger window goes down fine but when I put it back up it gets half way then slows down then just puts its self Down again! So I have to get some one to pull the button whilst I lift the window! Any ideas? Thanks
  • Views 832
Have you checked the wires between the drivers side door and cabin of the car? I had trouble with my windows and I checked my wires and 3 had split, I suggest check the wires there and the wires between the passenger side door too.
As above check the wiring, and also the window may well have come off the runners, you will have to take the door card off and peel off the membrane then out the window half way down and look/feel around where te window attaches to the runners, most probably needs to e clicked back on. If it broken(common) then undo the two 10mm bolts holdin the widow in an remove the window from the top, then undo all the other 10mm bolt 4-5 and unplug the connector the take the whole thing out from the bottom. What I have done before is use a thick screw and cup/large washer to fix the bracket to the runner as usually the clip parts are broken, then I'd you want to, use some silicone to stop it rattling about then but the whole thing back together. It is omportant to fit the brackets on straight when refitting so line them up and gently push the window down into place then tighten up the bolts.
HTH
