door locks
both of my dooe locks drivers/passangers have stopped workin :x both at the same time the key turns but nothink happends, do i get one of there...160798141158 (ebay item num), or do i buy a new lock alltogether? hope someone can help.
  • Views 808
It's a 6n2/ late 6n right? Then yes that kit will do it.
If fairly common for this to happen, and it's a bit difficult at first to fit the spring part in the right place but once you have done one you can do 100, best way I have found is to use needle nose plliers to guide the spring into place. There are a lot of guides for this online but none have used needle nose piers.
HTH
HTH
cheers mate thanks for the help
