MK2 Bolt on Front Panet
Reet. I'm going to do this to mine as I think its pretty cool and aids access to the bay a bit. Also, my fornt valance in slightly damaged and I want to use a repair panel to make it perfect. Now, I've seen this done several ways. One is to have the valance removable, but leave the slam panel and bonnet catch mech in place and the other is to leave the valance in place but remove the slam panet bonnet catch. Has anyone done both?
Also, does the front valance need cutting from the chassis legs? Looks like it does but I don't want to go hacking at chassis legs to find I'm cutting at the wrong bit. I'm not with the car atm, so I can't have a look. But from what I remember, this is the case?
  • Views 842
i had my slam panel on the old mk2 bolted on.
i just drilled out the rivets and put bolts with screwdriver heads (as there shallower) where the holes were :)
Your front valance was left in place though yeah? I looked for the build thread with this in as I knew you had done it but has it been removed?
yeah i left the valance, just had the slam panel removable. valance would be a bit overkill IMO, ill have a look dude.
Yeah it probably is, but since I need to have it off anyway, I may as well make it removable/easily replaceable. Also it gives nice access to the front cross member for IC placement/access if I end up doing the turbo conversion
yeah thats a fair point.
couldnt find any pics of mine in my old build thread. sorry mate
