Mk 3 polo coupe restoration
Hi I'm in the midst of restoring a MK3 polo CL coupe. It was my first car but has seen a bit of damaged over the past 6/7 years(!). Just 60k on the clocks so engine etc running fine and I've had it since it had 6k in 2005 where is was in pretty much show room condition.
The body work is in pretty bad shape at the moment due to a crash in 2006 which I'm replacing the damaged parts with a new door and front wing. The other side has also seen some damage this year due to some drunk people knocking the car at night, so I'm going to try and fix these body parts myself as they aren't too bad.
Plan for restoration is;
Stage 1 (next few weeks!)
Repair damaged body parts (new door & wing, and DIY carpark dents!), and respray for new door and wing.
Clear tinted front indys
Late spec g40 tinted rear lights
g40 tinted side lights
GT wheel arches and trim
GT interior (if I find some in good condition)
General clean and fix up to as good condition as possible
Damaged bodywork from crash
Car park dents (not that clear)
Parts to work with for now (Mostly from MarcusG40 from the forum who was breaking a pretty decent car!).
Stage 2 (when I get enough money!)
GT engine and some extra engine mods in next year
Advice I need to get started are (bit of a novice so some might seem completely obvious :)
1) How do I add/ remove the exterior trim (does it slide off or do I have to pull them off with force as they seem pretty secure, but I don't want to damage anything (never done this before and don't want to break anything)?
2) Some of the trim attachment was partly ripped off the rear side panel during the crash so I need some sort of adhesive to reattach it to the car?
3) I had some stickers on there and they have completely corroded and seem to have become permanently stuck on and I'm trying to remove them. Tried using T-cut but no use. Anybody got any ideas on how to remove them?
4) And how do I remove the interior rear door cards to get access to the bodywork so I can have a go at fixing the less damaged body parts?
5) Does anybody know where I can get a rubber mallet etc to repair car dents?
- Also are there any threads or advice someone could give on repairing bodywork damage such as carpark dents yourself.
Any advice will be hugely appreciated. =)
Cheers!
Edited by Nick_593
  • Views 1.3k
Popular Days
The side trim just pulls off, mine was a little stuck, but with a little convincing soon clicked away. While it was off I used tiger seal on the attaching part to make sure it doesn't come away again!
Theres a guide in the FAQ.
