1992 MK1 Volkswagen Caddy Sport with TSR tuned 8v
******REVISED PRICE AND UPDATES BELOW + NEW PHOTOS******
The time has finally come for me to part ways with my caddy. It was my first car and its taught me everything I know about cars! However I have gotten into drifting in a big way so need money to fund a drift daily.
(no longer has the strut brace or toolbox)
Below is a detailed spec list of the car, the modifications, and the extras I've acquired over my 3-year ownership.
Engine spec:
Rolling roaded at 140bhp at the flywheel
TSR Donnington 8v Over bored from 1.8 to 1.9
Reconditioned and gas flowed cylinder head
Reprofiled valves and valve seats
272 degree Kent high lift camshaft
Flywheel lightened from 5.5kg to 3.6kg
Twin weber 40 carburetors
Custom twin carb manifold ported and polished
Mild steel 4 branch manifold with heatshield
Custom stainless exhaust from the manifold back complete with flexi section, single rear backbox and 3” rolled tailpipe – made by Longlife Exhausts
Facet solid state electric fuel pump
Fuel pressure regulator
Inline fuel filter
Uprated HT leads
Recent sachs clutch
Diesel 8v gearbox
Engine bay:
Front motorsport design custom engine mount
Left and right engine/gearbox mounts polybushed
Diesel rear gearbox mount
Samco white coolant hoses
TSR fully adjustable rose jointed gear linkage
Mk2 golf gti 16v 9” brake servo and 22mm master cylinder fitted
All associated steel brake lines replaced with new copper brake lines
Oil catch can
Recent bosch battery
Engine bay resprayed in black
Custom mounted washer jets concealed under raised bonnet, operated by a button on the dashboard
Horn rewired to a button on the dashboard
Running gear:
Vmaxx front adjustable coilovers
Rear axle professionally flipped and centralised on original sport leaf springs
Height adjustable leaf spring shackle kit fitted for quick rear ride height adjustment
Two leaf spring bushes replaced with polybushes, remaining 4 are supplied with the car
4 x scirocco 14” bottle cap alloys with falken directional all season tyres with plenty of tread
2x 15mm hubcentric spacers
Spare wheel under car, holds air with plenty of tread
Mk1 golf gti vented drilled and grooved front brake disks
Mk1 golf gti brake pads
Interior:
*Custom black/red vinyl gti themed door cards
*Rare full chrome vw beetle interior door handles
Original sport steering wheel
Gti centre console with fully functional back-lit oil pressure and oil temp gauges
*Rear 4 piece tinted sliding window
*Original optional extra colour coded gti wing mirrors, adjustable from inside
Subtle but effective radio aerial strip fitted to top of windscreen
Black/red floor mats
Gti clocks with rev counter
*Momo gear knob
*Momo near new 280mm team steering wheel
*Momo steering wheel boss
*Quick release snap off steering boss kit
Exterior:
Door handles removed and doors welded and smoothed
Remote operated solenoid door popper for drivers side
Passenger side can be opened with a small 9v battery from outside of the car should remote control be lost/fail
*Good condition original tailgate with chrome handle
Original Sport rear bumper with tow bar + electrics and number plate support
Fog light wired up to replace right hand reverse light
Original sport twin lamp grill
*Painted gti grill badge
*Original golf gti red metal grill trim
Inner spot lamps tinted yellow
Near new lightly smoked headlights
Custom repainted Golf GX front bumper
Entire front panel replaced with brand new original vw front panel by a retro bodywork specialist
Clear side repeaters
Clear front indicators
*GTI colour coded wing mirrors, adjustable from the inside
Extras:
*Spare set of original rear light pods
P/s & d/s new replacement sill panels
P/s new rear arch replacement panel
Original 5.5kg flywheel
Replacement steering column gaiter
*4x individual Ramair carb filters
original brake servo and master cylinder in working order
original Perspex rear window
MOT until end of July 2013
TAX until 31st December 2012
The mileage of the car is unknown as the engine and clocks are not original and the speedo does not currently work, however I believe it to be the Speedo cable at fault, which is a simple fix. Paintwork was done a year or 2 ago by myself so its looking tired, and there is primer overspray in the bed. The shell has had welding done for previous MOTs but this was done to a very high standard and all traces of rust were removed. However the sills and B pillars are showing signs of rust. I have purchased the relevant replacement body panels but have not got round to having the welding done yet. You can see in the photo rust on the rear wheel arch. This is not structural and was not a problem in the MOT but I do have an arch repair panel which will come with the car. I also have plastic arch splats which cover it up in the mean time (removed to get honest photos). Comes with the original Volkswagen ignition key and one spare that I had cut. I have a lot of previous service history for this car and have kept every single receipt and invoice for parts and labour relating to it since I bought it. It has had fresh oil every few thousand miles. Most recently replaced parts include thermostat, oil pump, oil pick up, spark plugs, rocker cover gasket, sump gasket, cambelt, water pump, radiator, track rod ends, steering rack gaitors, and cv joints. I recently had the tracking and wheel alignment done to add some camber to the front wheels. I have print outs to show exact settings and it drives nice and straight with plenty of grip.
Recently I have had running issues with the car. It runs and performs as it should above 2.5k revs but below this it is lumpy and will not idle. I believe the problem to be the accelerator pump mech in one of the carburettors and but after a quick look over them cant see a problem. It ran perfectly until the other week and made 140bhp on the rolling road. Needs someone to spend some time tweaking the carbs or replacing but I do not have the time or money so have reduced the asking price by more than enough to factor in new webers and labour.
I dont want to break the car for parts but in the interest of a quicker sale I am considering removing some parts to sell separately and replacing with standard parts to keep the caddy 100% complete, and so...
£1750 for everything mentioned
or
£1500 without any of the things marked with * (standard parts fitted where necessary)
I am open to offers and negotiations as I have bought another car and need this gone to pay for insurance!
Car is located in Billingshurst, West Sussex
Call/text me on 07521575928 with any questions
Edited by conor1992
  • Replies 8
  • Views 1.3k
Fancy a swap for my bmw 318ti sport compact but has the 1.9 16v engine in it its just past it's mot and I've taxed it it's a fun car realy lively nice drive leather seats m3 bumpers it's got 113k on the clock 2 nearly new tyres
Thanks for the offer
Would be dependent on how much money on top my way, but ideally i am after something with a bit more power
I'm going on holiday this week, and if theres still no serious interest in the caddy when I return on the 25th then I will begin selling off parts individually whilst still keeping the caddy complete and usable
I will now consider offers for any of the bolt on parts
Advert amended, please re-read spec list
Very interested but Can you post pic's of how it is now Thanks
Edited by quiksilver_jake
Sorry only just seen this. Yes I can, ill get some good pics tomorrow
New photos added above ^
